[mapserver-users] libssl.so.6 error
Daniel Morissette
dmorissette at mapgears.com
Fri Aug 15 07:28:38 EDT 2008
Steve Smith wrote:
> There is no option for ssl in the configure file. I do see links to it
> in my make out put.
> However, I have not found reference to it in mapserver documentation. Do
> you know
> if it is required? If I am having this problem it must be.
libssl is probably pulled by libcurl.
As Paul wrote, you are better recompile on the new platform. Symlinks
may work if you're lucky, but can also cause all sorts of runtime errors
like the memory corruption errors that you got.
Daniel
Daniel Morissette
http://www.mapgears.com/
