[mapserver-users] WMS Request issue
Maarten Plieger
plieger at knmi.nl
Fri Aug 15 11:13:11 EDT 2008
Hi Brian,
Mapserver is actually executed and sends an error report back to you:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
Your layers parameter is wrong, it should be parcels instead of parcelswms:
http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&service=WMS&version=1.1.1&request=GetMap&layers=parcels&styles=default&srs=EPSG:26915&bbox=276595,5065831,342552,5113395&width=600&height=500&format=image/png
When you use version 1.0.0 instead of 1.1.1 the error is reported as an
image, so you can read it in your browser.
Regards,
Maarten Plieger
Fischer, Brian schreef:
> MapServer users:
> Has anyone else ran into this issue. I am trying to access a WMS
> service I setup through a web browser to test it and the browser keeps
> prompting me to download mapserv.exe instead of executing it. Any
> ideas why it works on a non-wms request and not the wms getmap
> request? Both are using the same location and .exe on the server. It
> is using MapServer 5.2 from MS4W 2.2.8. Thanks, Brian
> If I do a non-wms request it works (example below):
> http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&mapext=276595%205065831%20342552%205113395&mapsize=821%20638&mode=map&layers
> <http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&mapext=276595%205065831%20342552%205113395&mapsize=821%20638&mode=map&layers>=
> If I do a WMS GetMap request it prompts me to download the .exe:
> http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&service=WMS&version=1.1.1&request=GetMap&layers=parcelwms&styles=default&srs=EPSG:26915&bbox=276595,5065831,342552,5113395&width=600&height=500&format=image/png
> <http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&service=WMS&version=1.1.1&request=GetMap&layers=parcelwms&styles=default&srs=EPSG:26915&bbox=276595,5065831,342552,5113395&width=600&height=500&format=image/png>
> The mapfile is pretty straightforward as well.
> MAP
> NAME 'DouglasOGC'
> SIZE 800 650
> STATUS ON
> EXTENT 5069486 285288 5109721 334186
> UNITS METERS
> FONTSET 'fonts/fontset.list'
> SYMBOLSET 'symbols/symbol.sym'
> CONFIG "PROJ_LIB" "C:\proj\nad"
> PROJECTION
> "init=epsg:26915"
> END
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_title" "Douglas County WMS Server"
> "wms_onlineresource" "http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&"
> "wms_srs" "EPSG:26915"
> "wms_abstract" "The Douglas County WMS server has been setup for
> testing purposes only. The data should not be used for any official
> decisions"
> "wfs_title" "Douglas County WFS Server"
> "wfs_onlineresource"
> "wfs_srs" "EPSG:26915"
> "wfs_abstract" "The Douglas County WFS server has been setup for
> decisions"
> END
> END
> LEGEND
> STATUS ON
> END
> LAYER # Parcel Polygon Layer
> NAME parcels
> METADATA
> "wms_title" "parcelwms"
> 'WMS_FEATURE_INFO_MIME_TYPE' 'text/plain'
> "wfs_title" "parcelwfs"
> "gml_featureid" "FID"
> "gml_include_items" "PIN,GIS_ACRES,TAXPAYER"
> END
> DATA 'ogc/parcels_utm15'
> DUMP TRUE
> #MAXSCALE 50000
> #MINSCALE 500
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:26915"
> END
> CLASS
> NAME "Parcels"
> SYMBOL 'plainline'
> COLOR -1 -1 -1
> OUTLINECOLOR 153 255 153
> SIZE 1.5
> END
> END # Parcels Polygon Layer
> END ## end Map
> *Brian Fischer,* CFM
> GIS Project Manager
> */Houston Engineering, Inc./* | Leave Nothing to Chance^TM
> 6901 East Fish Lake Road, Suite 140
> Maple Grove, MN 55369
> Phone: 763.493.4522 / Fax: 763.493.5572
> Email: _bfischer at houstonengineeringinc.com_
> <mailto:bfischer at houstonengineeringinc.com>
> Website: _www.houstonengineeringinc.com_
> <http://www.houstonengineeringinc.com/>
> mapserver-users at lists.osgeo.org
Maarten Plieger
KNMI, R&D Information and Observation Technology, De Bilt
(t) +31 30 2206330
