[mapserver-users] WMS Request issue
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 15 11:19:37 EDT 2008
File you are prompted to download is not the mapserv.exe you believe. It is xml text file and if you just download it and open it you'll see:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
However, using layers=parcels does not give an image either, but this message this time:
msEvalRegex(): Regular expression error. String (/ms4w/apps/GeoMOOSE/douglas/maps_douglas/douglas_ogc.map&service=WMS&version=1.1.1&request=GetMap&layers=parcels&styles=default&srs=EPSG:26915&bbox=276595,5065831,342552,5113395&width=600&height=500&format=image/jpeg) failed expression test.
Go on trying, we will certainly do it!
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Fischer, Brian
Lähetetty: pe 15.8.2008 17:52
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] WMS Request issue
MapServer users:
Has anyone else ran into this issue. I am trying to access a WMS
service I setup through a web browser to test it and the browser keeps
prompting me to download mapserv.exe instead of executing it. Any ideas
why it works on a non-wms request and not the wms getmap request? Both
are using the same location and .exe on the server. It is using
MapServer 5.2 from MS4W 2.2.8. Thanks, Brian
If I do a non-wms request it works (example below):
http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMOO
SE/douglas/maps_douglas/douglas_ogc.map&mapext=276595%205065831%20342552
%205113395&mapsize=821%20638&mode=map&layers
<http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMO
OSE/douglas/maps_douglas/douglas_ogc.map&mapext=276595%205065831%2034255
2%205113395&mapsize=821%20638&mode=map&layers> =
If I do a WMS GetMap request it prompts me to download the .exe:
t=GetMap&layers=parcelwms&styles=default&srs=EPSG:26915&bbox=276595,5065
831,342552,5113395&width=600&height=500&format=image/png
st=GetMap&layers=parcelwms&styles=default&srs=EPSG:26915&bbox=276595,506
5831,342552,5113395&width=600&height=500&format=image/png>
The mapfile is pretty straightforward as well.
MAP
NAME 'DouglasOGC'
SIZE 800 650
STATUS ON
EXTENT 5069486 285288 5109721 334186
UNITS METERS
FONTSET 'fonts/fontset.list'
SYMBOLSET 'symbols/symbol.sym'
CONFIG "PROJ_LIB" "C:\proj\nad"
PROJECTION
"init=epsg:26915"
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Douglas County WMS Server"
"wms_onlineresource"
"http://douglas.houstoneng.com/cgi-bin2/mapserv.exe?map=/ms4w/apps/GeoMO
OSE/douglas/maps_douglas/douglas_ogc.map&"
"wms_srs" "EPSG:26915"
"wms_abstract" "The Douglas County WMS server has been setup for
testing purposes only. The data should not be used for any official
decisions"
"wfs_title" "Douglas County WFS Server"
"wfs_onlineresource"
"wfs_srs" "EPSG:26915"
"wfs_abstract" "The Douglas County WFS server has been setup for
decisions"
END
END
LEGEND
STATUS ON
END
LAYER # Parcel Polygon Layer
NAME parcels
METADATA
"wms_title" "parcelwms"
'WMS_FEATURE_INFO_MIME_TYPE' 'text/plain'
"wfs_title" "parcelwfs"
"gml_featureid" "FID"
"gml_include_items" "PIN,GIS_ACRES,TAXPAYER"
END
DATA 'ogc/parcels_utm15'
DUMP TRUE
#MAXSCALE 50000
#MINSCALE 500
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:26915"
END
CLASS
NAME "Parcels"
SYMBOL 'plainline'
COLOR -1 -1 -1
OUTLINECOLOR 153 255 153
SIZE 1.5
END
END # Parcels Polygon Layer
END ## end Map
Brian Fischer, CFM
GIS Project Manager
Houston Engineering, Inc. | Leave Nothing to ChanceTM
6901 East Fish Lake Road, Suite 140
Maple Grove, MN 55369
Phone: 763.493.4522 / Fax: 763.493.5572
Email: bfischer at houstonengineeringinc.com
<mailto:bfischer at houstonengineeringinc.com>
Website: www.houstonengineeringinc.com
<http://www.houstonengineeringinc.com/>
