[mapserver-users] WFS server configuration problems...
bartvde at osgis.nl
bartvde at osgis.nl
Mon Aug 18 09:44:32 EDT 2008
Is you data inside of the MAP->extent?
Best regards,
Bart
> Hi all again =)
> Nowadays Iâm trying to fire up a WFS server based on Mapserver 5.0.2,
> but
> I have a problem with it. This is what I have:
> 1) mapserv âv output:
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER INPUT=TIFF
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> 2) My MAP file:
> MAP
> UNITS METERS
> EXTENT 1373.000000 1663.000000 2073.000000 2163.000000
> SIZE 1095 565
> SHAPEPATH "/var/www/map/shapes"
> SYMBOLSET "/var/www/map/symbols/symbols.sym"
> FONTSET "/var/www/map/fonts/fonts.list"
> IMAGECOLOR 255 255 255
> TEMPLATEPATTERN 'map*'
> WEB
> TEMPLATE '/var/www/map/map.html'
> IMAGEPATH '/var/www/map/tmp/'
> IMAGEURL '/map/tmp/'
> METADATA
> wfs_title "WFS Demo"
> wfs_onlineresource
> "http://localhost/cgi-bin/mapserv?map=wfs.map&"
> wfs_srs "EPSG:32235"
> END
> END
> PROJECTION
> "init=epsg:32235"
> END
> LAYER
> NAME "Housepoints"
> CONNECTIONTYPE postgis
> CONNECTION "user=mapserv dbname=mapserv host=127.0.0.1
> port=5432"
> DATA "wkb_geometry from polymap"
> STATUS ON
> TYPE POINT
> LABELITEM "label"
> TOLERANCE 7
> HEADER '/var/www/map/templates/templ_head.html'
> FOOTER '/var/www/map/templates/templ_footer.html'
> DUMP TRUE
> METADATA
> wfs_title "houses"
> gml_featureid "msGeometry"
> gml_include_items "all"
> END
> PROJECTION
> "init=epsg:32235"
> END
> CLASS
> NAME "housepoints"
> TEMPLATE '/var/www/map/templates/templ_query.html'
> STYLE
> SYMBOL 'circle'
> COLOR [color]
> OUTLINECOLOR 0 0 0
> SIZE [size]
> END
> LABEL
> COLOR 0 0 255
> POSITION AUTO
> PARTIALS TRUE
> MINDISTANCE 100
> BUFFER 2
> ENCODING CP1251
> WRAP '~'
> END
> END
> END
> END
> This mapfile is a working one, only âmetadataâ sections added.
> 3) A part of
> http://localhost/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getcapabilities
> output:
> <FeatureTypeList>
> <Operations>
> <Query/>
> </Operations>
> <FeatureType>
> <Name>Housepoints</Name>
> <Title>houses</Title>
> <SRS>EPSG:32235</SRS>
> <LatLongBoundingBox minx="-178.487" miny="-8.24225e+12" maxx="170.758"
> maxy="8.24225e+12"/>
> </FeatureType>
> </FeatureTypeList>
> 4)
> http://172.20.200.200:8080/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Housepoints
> output:
> <schema targetNamespace="http://mapserver.gis.umn.edu/mapserver"
> elementFormDefault="qualified" version="0.1">
> <import namespace="http://www.opengis.net/gml"
> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
> <element name="Housepoints" type="ms:HousepointsType"
> substitutionGroup="gml:_Feature"/>
> <complexType name="HousepointsType">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element name="msGeometry" type="gml:GeometryPropertyType" minOccurs="0"
> maxOccurs="1"/>
> <element name="ogc_fid" type="string"/>
> <element name="cat" type="string"/>
> <element name="label" type="string"/>
> <element name="color" type="string"/>
> <element name="size" type="string"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> 5) And now -
> http://172.20.200.200:8080/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=Housepoints
> output:
> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Housepoints&OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:null>missing</gml:null>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> Why am I having âmissingâ here? =/
> ÐÑпÑавлено M2, ÑеволÑÑионной поÑÑовой
> пÑогÑаммой Opera:
> http://www.opera.com/mail/
> mapserver-users at lists.osgeo.org
