[mapserver-users] WFS server configuration problems...
George A. Dubin
lysholm at tut.by
Mon Aug 18 10:06:24 EDT 2008
=)) Nope... I hadn't... After changing EXTENT to
EXTENT 0 0 12000 16300
everything works fine!
Really big TNX for quick answers! I was struggling with this problem since
friday =/
On Mon, 18 Aug 2008 16:44:32 +0300, <bartvde at osgis.nl> wrote:
> Is you data inside of the MAP->extent?
> Best regards,
> Bart
>> Hi all again =)
>> Nowadays I'm trying to fire up a WFS server based on Mapserver 5.0.2,
>> but
>> I have a problem with it. This is what I have:
>> 1) mapserv -v output:
>> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER INPUT=TIFF
>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> 2) My MAP file:
>> MAP
>> UNITS METERS
>> EXTENT 1373.000000 1663.000000 2073.000000 2163.000000
>> SIZE 1095 565
>> SHAPEPATH "/var/www/map/shapes"
>> SYMBOLSET "/var/www/map/symbols/symbols.sym"
>> FONTSET "/var/www/map/fonts/fonts.list"
>> IMAGECOLOR 255 255 255
>> TEMPLATEPATTERN 'map*'
>> WEB
>> TEMPLATE '/var/www/map/map.html'
>> IMAGEPATH '/var/www/map/tmp/'
>> IMAGEURL '/map/tmp/'
>> METADATA
>> wfs_title "WFS Demo"
>> wfs_onlineresource
>> "http://localhost/cgi-bin/mapserv?map=wfs.map&"
>> wfs_srs "EPSG:32235"
>> END
>> END
>> PROJECTION
>> "init=epsg:32235"
>> END
>> LAYER
>> NAME "Housepoints"
>> CONNECTIONTYPE postgis
>> CONNECTION "user=mapserv dbname=mapserv host=127.0.0.1
>> port=5432"
>> DATA "wkb_geometry from polymap"
>> STATUS ON
>> TYPE POINT
>> LABELITEM "label"
>> TOLERANCE 7
>> HEADER '/var/www/map/templates/templ_head.html'
>> FOOTER '/var/www/map/templates/templ_footer.html'
>> DUMP TRUE
>> METADATA
>> wfs_title "houses"
>> gml_featureid "msGeometry"
>> gml_include_items "all"
>> END
>> PROJECTION
>> "init=epsg:32235"
>> END
>> CLASS
>> NAME "housepoints"
>> TEMPLATE '/var/www/map/templates/templ_query.html'
>> STYLE
>> SYMBOL 'circle'
>> COLOR [color]
>> OUTLINECOLOR 0 0 0
>> SIZE [size]
>> END
>> LABEL
>> COLOR 0 0 255
>> POSITION AUTO
>> PARTIALS TRUE
>> MINDISTANCE 100
>> BUFFER 2
>> ENCODING CP1251
>> WRAP '~'
>> END
>> END
>> END
>> END
>> This mapfile is a working one, only "metadata" sections added.
>> 3) A part of
>> http://localhost/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getcapabilities
>> output:
>> <FeatureTypeList>
>> <Operations>
>> <Query/>
>> </Operations>
>> <FeatureType>
>> <Name>Housepoints</Name>
>> <Title>houses</Title>
>> <SRS>EPSG:32235</SRS>
>> <LatLongBoundingBox minx="-178.487" miny="-8.24225e+12" maxx="170.758"
>> maxy="8.24225e+12"/>
>> </FeatureType>
>> </FeatureTypeList>
>> 4)
>> http://172.20.200.200:8080/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Housepoints
>> output:
>> <schema targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>> elementFormDefault="qualified" version="0.1">
>> <import namespace="http://www.opengis.net/gml"
>> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
>> <element name="Housepoints" type="ms:HousepointsType"
>> substitutionGroup="gml:_Feature"/>
>> <complexType name="HousepointsType">
>> <complexContent>
>> <extension base="gml:AbstractFeatureType">
>> <sequence>
>> <element name="msGeometry" type="gml:GeometryPropertyType" minOccurs="0"
>> maxOccurs="1"/>
>> <element name="ogc_fid" type="string"/>
>> <element name="cat" type="string"/>
>> <element name="label" type="string"/>
>> <element name="color" type="string"/>
>> <element name="size" type="string"/>
>> </sequence>
>> </extension>
>> </complexContent>
>> </complexType>
>> </schema>
>> 5) And now -
>> http://172.20.200.200:8080/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=Housepoints
>> output:
>> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>> wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Housepoints&OUTPUTFORMAT=XMLSCHEMA">
>> <gml:boundedBy>
>> <gml:null>missing</gml:null>
>> </gml:boundedBy>
>> </wfs:FeatureCollection>
>> Why am I having "missing" here? =/
>> Отправлено M2, революционной почтовой
>> программой Opera:
>> http://www.opera.com/mail/
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Отправлено M2, революционной почтовой программой Opera:
