[MAPSERVER-USERS] Use of "gutter" parameter with tilecache
Ritesh Ambastha
group.ritesh at gmail.com
Mon Aug 18 07:34:17 PDT 2008
I want to specify "gutter" parameter while using tilecache.
This is the code snippet from my "tilecache.cfg" file:
<snip>
[cache]
type=Disk
base=/var/www/tilecache
# My MapServer layer configuration.
[mycity]
type=MapServer
layers=layer1,layer2,layer3
mapfile=/var/www/mymap/mymap.map
levels= 7
resolutions = 66.14, 26.45, 13.22,6.614,2.64,1.322,0.26
maxResolution = 66.14
srs=EPSG:4326
bbox = -1008136, 2136130, -937979, 2198657
</snip>
I do know how to specify the "gutter" parameter while accessing these tiles
via openlayers. I am looking for the config lines for generating tiles while
using this "gutter" param.
Regards,
Ritesh Ambastha
View this message in context: http://www.nabble.com/Use-of-%22gutter%22-parameter-with-tilecache-tp19033034p19033034.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
