[mapserver-users] Fractional line widths?
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Aug 19 08:39:20 EDT 2008
We've talked about this as part of a package of graphics-related enhancements. Look for
it in 5.4 soon.
Steve
>>> "Tamas Szekeres" <szekerest at gmail.com> 08/18/08 7:06 PM >>>
Dane,
I think it would be implemented by means of replacing the int-s with
doubles at the style and the symbol definitions and the corresponding
interfaces since AGG have already been using doubles internally in the
code.
Best regards,
Tamas
2008/8/19 Dane Springmeyer <blake at hailmail.net>:
> Tamas,
> Great, thanks!. I'll file a ticket then regarding the agg render and adding
> a FORMATOPTION for generating 'thinner' looking lines.
> My question comes from the context of comparing Mapnik's agg output to
> mapserver. Mapnik seems to interpret user-entered fractional widths in a
> clever way, by lightening the color and intensity.
> I'm comparing this graphic generated with a width=0.1 with Mapnik:
> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/xml_config/map/hello_world_using_xml_config.png
> to this graphic generated with Mapserver with Width 1.0:
> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/mapserver_comparison/mapfile_config/map/hello_world_with_mapserver_mapfile.png
> It fully possible that my mapfile is not doing an equal comparison, so if
> anyone has suggestions I've pasted it below.
> Thanks,
> Dane
> # This mapfile mirrors the mapnik hello world example
> here: http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/pure_python/
> # A map can be generated from it by running shp2img.
> # For example:
> # $ shp2img -m world.map -o map/hello_world_with_mapserver_mapfile.png
> # or
> # once you have installed the mapserv cgi use this url:
> http://localhost/cgi-bin/mapserv?map=/path/to/this/mapfile/world.map&layers=world&mode=map
> MAP
> IMAGETYPE AGG
> EXTENT -180 -93 180 86
> SIZE 600 300
> SHAPEPATH "../../data/"
> IMAGECOLOR 70 130 180
> OUTPUTFORMAT
> NAME 'AGG'
> DRIVER AGG/PNG
> IMAGEMODE RGB
> MIMETYPE "image/png"
> END
> LAYER
> NAME world
> DATA world_borders.shp
> STATUS ON
> TYPE POLYGON
> CLASS
> NAME "World"
> STYLE
> COLOR 242 239 249
> OUTLINECOLOR 127 127 127
> WIDTH 1
> END
> END
> END
> END
> On Aug 18, 2008, at 3:53 PM, Tamas Szekeres wrote:
> Dane,
> I think it's reasonable but would only be feasible for the AGG renderer
> though.
> Best regards,
> Tamas
> I can see from http://mapserver.gis.umn.edu/docs/reference/mapfile/style
> that only integers are supported for the Style > Width parameter.
> Are thinner lines (a float type) a possibility or have they been considered
> in the MapServer code base?
> I can't find anything in trac to suggest so, but I thought to check here
> before filing a ticket.
> Thanks,
> Dane
> mapserver-users at lists.osgeo.org
