[mapserver-users] Fractional line widths?
Dane Springmeyer
blake at hailmail.net
Mon Aug 18 19:26:18 EDT 2008
Tamas,
Great, thanks!. I'll file a ticket then regarding the agg render and
adding a FORMATOPTION for generating 'thinner' looking lines.
My question comes from the context of comparing Mapnik's agg output to
mapserver. Mapnik seems to interpret user-entered fractional widths in
a clever way, by lightening the color and intensity.
I'm comparing this graphic generated with a width=0.1 with Mapnik:
http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/xml_config/map/hello_world_using_xml_config.png
to this graphic generated with Mapserver with Width 1.0:
http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/mapserver_comparison/mapfile_config/map/hello_world_with_mapserver_mapfile.png
It fully possible that my mapfile is not doing an equal comparison, so
if anyone has suggestions I've pasted it below.
Thanks,
Dane
# This mapfile mirrors the mapnik hello world example here: http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/pure_python/
# A map can be generated from it by running shp2img.
# For example:
# $ shp2img -m world.map -o map/hello_world_with_mapserver_mapfile.png
# or
# once you have installed the mapserv cgi use this url:
# http://localhost/cgi-bin/mapserv?map=/path/to/this/mapfile/world.map&layers=world&mode=map
MAP
IMAGETYPE AGG
EXTENT -180 -93 180 86
SIZE 600 300
SHAPEPATH "../../data/"
IMAGECOLOR 70 130 180
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
MIMETYPE "image/png"
END
LAYER
NAME world
DATA world_borders.shp
STATUS ON
TYPE POLYGON
CLASS
NAME "World"
STYLE
COLOR 242 239 249
OUTLINECOLOR 127 127 127
WIDTH 1
END
END
END
END
On Aug 18, 2008, at 3:53 PM, Tamas Szekeres wrote:
> Dane,
> I think it's reasonable but would only be feasible for the AGG
> renderer though.
> Best regards,
> Tamas
> 2008/8/19 Dane Springmeyer <blake at hailmail.net>:
>> I can see from http://mapserver.gis.umn.edu/docs/reference/mapfile/style
>> that only integers are supported for the Style > Width parameter.
>> Are thinner lines (a float type) a possibility or have they been
>> considered
>> in the MapServer code base?
>> I can't find anything in trac to suggest so, but I thought to check
>> here
>> before filing a ticket.
>> Thanks,
>> Dane
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080818/0e99186d/attachment-0001.html
