[mapserver-users] build mapserver 5.2.0 with proj 4.6.0
Jacolin Yves
yjacolin at free.fr
Tue Aug 19 06:06:31 EDT 2008
Arg, I built again proj4 and I successfully run the masperver configure
script :)
Y.
Le Tuesday 19 August 2008 11:44:00 Guillaume Sueur, vous avez écrit :
> what is surprising is that I have here an Ubuntu box with proj 4.6.0
> package and a mapserver 5.2.0 compiled on it without any problem.
> Jacolin Yves a écrit :
> > Hi Guillaume,
> > This is a fresh system install from a "virtual private server" under
> > OpenVZ, I tried to remove all packetage with apt-get remove, and nothing
> > is removed ;)
> > Furthermore I setup the option --with-proj which link to /usr/local/lib
> > where libproj is installed (by myself).
> > I built all main dependance (proj, gdal, geos, libecw and agg).
> > It seems that configure script test pj_transform in proj and if this is
> > not present, think it is an old proj release. I ma going to check in the
> > proj ML to know more about this.
> > Regards,
> > Y.
> > Le Tuesday 19 August 2008 11:31:36 Guillaume Sueur, vous avez écrit :
> >> make sure you don't have any pre-installed Proj lib which would get
> >> linked during the ./configure
> >>> Hello,
> >>> I am trying to build mapserver 5.2.0 with proj-4.6.0. The ./configure
> >>> script tells me : "configure: error: This version of PROJ is too old.
> >>> PROJ4.4.2 or later is required." , here is the configure comande line:
> >>> ./configure
> >>> --with-postgis
> >>> --with-wmsclient --with-wfsclient
> >>> --with-geos
> >>> --with-proj=/usr/local/
> >>> --with-gdal --with-ogr
> >>> --with-freetype=/usr/bin/freetype-config --with-eppl
> >>> --with-xpm=/usr/X11R6/lib/ --with-gd=/usr/
> >>> --with-agg=/mnt/data/compil/agg-2.5/
> >>> --with-curl-config=/usr/bin/curl-config
> >>> --with-tiff --with-xml2-config=/usr/bin/xml2-config
> >>> Do you know how to resolv this?
> >>> Thanks
> >>> Y.
Yves Jacolin
http://softlibre.gloobe.org
