Res: [mapserver-users] Change a class name by url
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Aug 19 12:36:47 EDT 2008
If you can recompile MapServer then all you need to do is edit
maplexer.l. Go
down to the line:
<INITIAL>name
and change it to:
<INITIAL,URL_STRING>name
and that should do it.
Steve
>>> On 8/19/2008 at 11:09 AM, in message
<307627.65224.qm at web34507.mail.mud.yahoo.com>, Jefferson Bauer
<jepibr at yahoo.com.br> wrote:
> Thaks for your reply
> Jeff.
> I've used the migration
> guide to change the way i modify variables by URL, like setting
> templates in WEB or LEGEND, adding POINTS in a FEATURE, etc.
> With that, my
> application works fine. But in some cases i need to modify the name
> of a class adding a number or a new text and this is the problem. In
> the older version it's quite simple as i wrote, but now i can't do
in
> this new way and the error message doesn't explain too much...
> Did you try to do this
> class name change? Do you know another way to this?
> Jefferson Bauer
> ----- Mensagem original ----
> De: Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Para: mapserver-users at lists.osgeo.org
> Enviadas: Terça-feira, 19 de Agosto de 2008 2:10:45
> Assunto: Re: [mapserver-users] Change a class name by url
> hmm, u might also refer to the 5.0 migration guide, in case it helps
> you:
http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MIGRATIO
> N_GUIDE.TXT
> I have also seen a variation of this error:
> http://lists.osgeo.org/pipermail/mapserver-users/2008-May/055877.html
