[mapserver-users] Fractional line widths?
Dane Springmeyer
blake at hailmail.net
Tue Aug 19 10:28:17 EDT 2008
Fantastic, thanks for the feedback everyone.
Dane
On Aug 19, 2008, at 5:39 AM, Steve Lime wrote:
> We've talked about this as part of a package of graphics-related
> enhancements. Look for
> it in 5.4 soon.
> Steve
>>>> "Tamas Szekeres" <szekerest at gmail.com> 08/18/08 7:06 PM >>>
> Dane,
> I think it would be implemented by means of replacing the int-s with
> doubles at the style and the symbol definitions and the corresponding
> interfaces since AGG have already been using doubles internally in the
> code.
> Best regards,
> Tamas
> 2008/8/19 Dane Springmeyer <blake at hailmail.net>:
>> Tamas,
>> Great, thanks!. I'll file a ticket then regarding the agg render
>> and adding
>> a FORMATOPTION for generating 'thinner' looking lines.
>> My question comes from the context of comparing Mapnik's agg output
>> to
>> mapserver. Mapnik seems to interpret user-entered fractional widths
>> in a
>> clever way, by lightening the color and intensity.
>> I'm comparing this graphic generated with a width=0.1 with Mapnik:
>> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/xml_config/map/hello_world_using_xml_config.png
>> to this graphic generated with Mapserver with Width 1.0:
>> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/mapserver_comparison/mapfile_config/map/hello_world_with_mapserver_mapfile.png
>> It fully possible that my mapfile is not doing an equal comparison,
>> so if
>> anyone has suggestions I've pasted it below.
>> Thanks,
>> Dane
>> # This mapfile mirrors the mapnik hello world example
>> here: http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/pure_python/
>> # A map can be generated from it by running shp2img.
>> # For example:
>> # $ shp2img -m world.map -o map/
>> # or
>> # once you have installed the mapserv cgi use this url:
>> http://localhost/cgi-bin/mapserv?map=/path/to/this/mapfile/world.map&layers=world&mode=map
>> MAP
>> IMAGETYPE AGG
>> EXTENT -180 -93 180 86
>> SIZE 600 300
>> SHAPEPATH "../../data/"
>> IMAGECOLOR 70 130 180
>> OUTPUTFORMAT
>> NAME 'AGG'
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> MIMETYPE "image/png"
>> END
>> LAYER
>> NAME world
>> DATA world_borders.shp
>> STATUS ON
>> TYPE POLYGON
>> CLASS
>> NAME "World"
>> STYLE
>> COLOR 242 239 249
>> OUTLINECOLOR 127 127 127
>> WIDTH 1
>> END
>> END
>> END
>> END
>> On Aug 18, 2008, at 3:53 PM, Tamas Szekeres wrote:
>> Dane,
>> I think it's reasonable but would only be feasible for the AGG
>> renderer
>> though.
>> Best regards,
>> Tamas
>> I can see from http://mapserver.gis.umn.edu/docs/reference/mapfile/style
>> that only integers are supported for the Style > Width parameter.
>> Are thinner lines (a float type) a possibility or have they been
>> considered
>> in the MapServer code base?
>> I can't find anything in trac to suggest so, but I thought to check
>> here
>> before filing a ticket.
>> Thanks,
>> Dane
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
