[mapserver-users] Corrupt image output
Tamas Szekeres
szekerest at gmail.com
Tue Aug 19 17:39:38 EDT 2008
Mike,
It's quite difficult to find out what's going on. You should file a
ticket including the example and sample data. Probably the problem may
be reproduced in other machines as well.
Best regards,
Tamas
2008/8/19 Mike Leahy <mgleahy at alumni.uwaterloo.ca>:
> Tamas,
> I just gave this a try a few times - deleted the cache, and loaded one tile.
> It seems to happen less frequently, but I still have about a 1 in 3 chance
> of getting various rectangle artifacts on the image. It basically looks
> like something forgets to draw one or more of the rgb colours.
> Mike
> Tamas Szekeres wrote:
>> Mike,
>> Did you experience the same problem when calling tile.php directly
>> when rendering an individual tile?
>> Best regards,
>> Tamas
>>> Hello list,
>>> I'm wondering if anyone can help me figure out a problem I'm having with
>>> corrupted output from from a tiled geotiff dataset I'm using in a ka-Map
>>> environment. You can see what's happening to the imagery here:
>>> http://img527.imageshack.us/my.php?image=corrupthd1.png
>>> This generally happens when I'm zoomed in fairly close, and usually with
>>> this high-resolution image dataset. However, I can get corrupted output
>>> for
>>> other raster datasets (all geotiff, but not always tiled). It seems to
>>> happen when the machine is processing most intensively (i.e., usually
>>> when
>>> the imagery is being rendered by ka-Map). It also seems to be limited to
>>> the laptop I am using, which is running F7-x86_64. In contrast, I have
>>> an
>>> actual server (F8-x86_64), which has a virtually identical setup (with
>>> respect to MapServer and its various dependencies), but with lots more
>>> cpu
>>> cores and ram, and it's having no trouble at all (as far as I have
>>> noticed).
>>> The corruption in the output from the same application my laptop is not
>>> always the same - if I clear the cache for ka-Map and re-render the
>>> images,
>>> I'll get similar artifacts appearing in the output (red, green, blue
>>> and/or
>>> black rectangles), but they will vary in size and location. It happens
>>> for
>>> both GD/AGG drivers, and JPEG/PNG output formats.
>>> Until now, I figured it was just a problem with limited memory on my
>>> laptop
>>> (it was always around 100% when rendering this imagery on the web service
>>> viewing the application in a browser), but now I've upgraded the ram -
>>> there's plenty of spare room and I'm still getting the same problem. I
>>> just
>>> finished upgrading Gdal from 1.5.0 to 1.5.2, and that didn't help any.
>>> Basically, the only real differences I can think of between my laptop and
>>> my
>>> server are the number of cpu cores (1 on my laptop vs. 8 on the server),
>>> and
>>> possibly the versions of some of the underlying libraries in the system.
>>> Does anyone know where I should start looking to find the cause of this?
>>> Or perhaps somebody recognizes this problem, and knows what I might be
>>> doing wrong...
>>> Thanks for any suggestions,
>>> Mike
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
