[MAPSERVER-USERS] fseek dbf error while importing shapefile in postgres
Ritesh Ambastha
group.ritesh at gmail.com
Tue Aug 19 08:05:27 PDT 2008
Dear Gregor,
Thanks for the quick support !
I checked the number of rows in the populated table in postgres against the
DBF. Both are equal.
I am unable to check the source of error.
Regards,
RItesh Ambastha
Gregor Mosheh-3 wrote:
> Ritesh Ambastha wrote:
>> fseek(-1035313584) failed on DBF file.
>> What can be the problem? What should be checked in the DBF for these kind
>> of
>> errors?
> Are you positive that the DBF was uploaded correctly? The first thing I
> would suspect is that I FTPd it in ASCII mode, or only got half of the
> file uploaded. Check the DBF and make sure it's the right size and
> md5sum, is my advice.
> Gregor Mosheh / Greg Allensworth, BS, A+
> System Administrator
> HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/fseek-dbf-error-while-importing-shapefile-in-postgres-tp19052192p19052353.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
