[mapserver-users] Using mapserver with EPSG:900913
Subha Ramakrishnan
subha at gslab.com
Wed Aug 20 11:30:00 EDT 2008
Hi :
We are building a map based web portal using openlayers ,UMN
mapserver[5.0.2] and postgis DB.We use google as the base map through
openlayers.We need to overlay our custom layers from the db on top of
this base map, for that we are using Mapserver (is run on a FC7 linux
machine). It is observed that by default openlayers converts google
projection [900913] to EPSG:4326 when the base map is fetched.
Now when we try to overlay an image that the mapserver generates, there
is a mismatch on the base map, though mapserver uses epsg::4326. After
searching over the internet theere seems to be only one solution which
is displaying the base map itself in epsg:900913 and emit the mapserver
image also in the same projection. The problem is we are not able to
generate an image through mapserver in epsg::900913.
We have taken following measures untill now :
1> For using epsg:900913 projection in mapserver, we have added
following entry in the /usr/local/share/proj/epsg file.[proj version 4.6]
"<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>" 2> We have
added following entry in the "in the spatial_ref_sys table in postgis DB.
"900913 ,'EPSG',900913,'GEOGCS["WGS 84", DATUM["World Geodetic System
1984", SPHEROID["WGS 84", 6378137.0,
298.257223563,AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich", 0.0,
AUTHORITY["EPSG","8901"]], UNIT["degree",0.017453292519943295],
AXIS["Longitude", EAST], AXIS["Latitude",
NORTH],AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],PARAMETER["semi_minor", 6378137.0],
PARAMETER["latitude_of_origin",0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor",1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0],UNIT["m", 1.0], AXIS["x", EAST],
AXIS["y", NORTH],AUTHORITY["EPSG","900913"]] |','+proj=merc +a=6378137
+b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
+nadgrids=@null +no_defs'); The mapfile is as follows: (With this, We
get a blank image without any exception.)
MAP
NAME MAP_POINTS
SIZE 725 800
IMAGETYPE PNG
EXTENT 6679169.446666667 -7.081154550627918 11131949.077777777
4865942.278825832
WEB
METADATA
wms_srs "EPSG:4326 EPSG:900913"
END
END
PROJECTION
"init=epsg:900913"
END
LAYER
CONNECTIONTYPE postgis
NAME indiastates
CONNECTION "user=postgres dbname=test host=localhost"
TYPE POINT
STATUS DEFAULT
#DATA "topology from states"
DATA "topology from india_states using unique id using SRID -1"
CLASS
COLOR 255 0 0
END
END
END
The client (openlayer) code is as follows :
options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508.34)
map = new OpenLayers.Map('map', options);
var gphy = new OpenLayers.Layer.Google("Google
Physical",{type: G_PHYSICAL_MAP,'sphericalMercator': true});
map.addLayers(gphy);
var lonLat = new OpenLayers.LonLat(82, 23) ;
lonLat.transform(map.displayProjection,map.getProjectionObject());
map.setCenter(lonLat,5);
var wms ;
wms = new OpenLayers.Layer.WMS( layername,
"http://localhost/cgi-bin/mapserv?",
{ map: 'demo.map',
projection:"EPSG:900913",
transparent: 'true', layers: 'indiastates',
format: 'image/png'},{singleTile: 'true'} );
map.addLayer(twms1);
Can anyone help us in any way?
Also,
We have tried overlaying layer fetched from our map server on
different basemaps from (meta carta and tera pages) and have found it
overlays perfectly So clearly there is is problem overlaying on google
map through openlayers in epsg : 4326.
Thanks and sorry for the long mail.
Expecting a reply.
Subha.
