[mapserver-users] Using space in layer's name?
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Aug 20 08:43:09 PDT 2008
Jukka is right, layernames with spaces will throw warnings in a WMS
GetCapabilities request.  Advice: never use spaces in a layername, period.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
kreshna_iceheart at yahoo.com wrote:
> Er, nope. I'm not using WMS.
> --- On Wed, 8/20/08, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
>> From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> Subject: Re: [mapserver-users] Using space in layer's name?
>> To: kreshna_iceheart at yahoo.com, mapserver-users at lists.osgeo.org
>> Date: Wednesday, August 20, 2008, 2:46 AM
>> Hi,
>> Are you using WMS?In the document "WMS servers with
>> MapServer"
>> http://mapserver.gis.umn.edu/docs/howto/wms_server
>> reads:
>> Layer Name and wms_title metadata:
>> Every individual layer needs its own unique name and title.
>> Layer names are also used in GetMap and GetFeatureInfo
>> requests to refer to layers that should be included in the
>> map output and in the query. Layer names must start with a
>> letter when setting up a WMS server (layer names should not
>> start with a digit or have spaces in them).
>> I believe that spaces in layer names are not allowed by WMS
>> standard, but I may be wrong.  I do also believe that
>> MapServer cgi supports them, at least I can find example map
>> files with layers named like "my layer".
>> -Jukka Rahkonen-
>>> -----Alkuperäinen viesti-----
>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org]
>> Puolesta
>>> Lähetetty: 20. elokuuta 2008 8:40
>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>> Aihe: [mapserver-users] Using space in layer's
>> name?
>>> I'm using MapServer 5.0.2.
>>> I have two layers: the first is named "jaringan
>> ipal dan
>>> iplt" (layer name contains space character),
>> while the second
>>> is named "jaringan_telepon" (does not
>> contain space).
>>> I am using the [layers] parameter to dynamically pass
>> my
>>> layers to another template for printing purpose. Alas,
>>> because one layer contains space, that particular
>> layer is
>>> not passed at all. Here is the contents of the
>> [layers] parameter:
>> &layers=jaringan%20ipal%20dan%20iplt%20jaringan_telepon
>>> The layer "jaringan_telepon" is displayed
>> correctly, but the
>>> layer "jaringan ipal dan iplt" fails to
>> display, because
>>> MapServer takes the space character (%20) as
>> delimiter.
>>> I tried to use the parameter [layers_esc] instead, and
>> here
>>> is the contents of the [layers_esc]:
>>> &layers=jaringan+ipal+dan+iplt+jaringan%5Ftelepon
>>> Here, the layer "jaringan ipal dan iplt"
>> still fails to
>>> display, because MapServer replaces the space with
>> "+" (plus
>>> sign), which is also used as delimiter.
>>> Thus, not even [layers_esc] allows us to use space
>> character
>>> in layer's name. Is there any other way to use
>> layer with
>>> space character in its name, then?
>>> Thanks,
>>> -Kresh
More information about the MapServer-users mailing list
