[mapserver-users] MULTIPOINT and POINT in same geometry column
Subha Ramakrishnan
subha at gslab.com
Fri Aug 22 02:51:32 EDT 2008
You can add a geometry column column of type geometry itself instead of
fixing it as point or multipoint.This will support all types of geometry
in one table.
Regards,
Subha
NASUNO Isao wrote:
> Hello all,
> Is there any way to append 'MULTIPOINT' shape files and 'POINT' shape files into
> same table with a geometry column ?
> I guess the geometry column should be 'MULTIPOINT' geometry-type,
> and the 'POINT' shape should be translated 'MULTIPOINT' (but only one point
> in one record)in the appending process.
> Any suggestions ?
> I'm using
> - PostgreSQL 8.0.3
> - PostGIS 1.1.3
> - Mapserver 4.10
> Thanks,
> Isao Nasuno
> mapserver-users at lists.osgeo.org
