[mapserver-users] [mapserver] Java - PostGIS - Quoting issue
in SQL request
julien
julien.trolet at ifremer.fr
Wed Aug 27 03:30:56 EDT 2008
Hello Karim,
As I reported in my first mail, it is the first pair of quotes like in
*'*France*'* which induce the error.
I tried *''*France*''*, with double single quote (*'*), but it is also
not working.
Thanks anyway for the help.
Julien
alim karim wrote:
> Perhaps you can try escaping your quotes like so:
> 'person's name' => 'person''s name'
> ak
> On Tue, Aug 26, 2008 at 8:16 AM, julien <julien.trolet at ifremer.fr
> <mailto:julien.trolet at ifremer.fr>> wrote:
> Hello,
> I am developing an interface for a PostreSQL/PostGIS (v8.2)
> database using Mapserver (v 5.2.0) and Java (v6.0).
> I obtained some nice maps using a basic SQL query, inserted into
> the mapfile.
> But as soon as I tried to _use some simple quote *'* or *\'*_, the
> server cannot draw the layer and report the following error :
> java.lang.UnknownError: msPOSTGISLayerRetrievePK(): Query error. Error executing POSTGIS statement (msPOSTGISLayerRetrievePK():select attname from pg_attribute, pg_constraint, pg_class where pg_constraint.conrelid = pg_class.oid and pg_class.oid = pg_attribute.attrelid and pg_constraint.contype = 'p' and pg_constraint.conkey[1] = pg_attribute.attnum and pg_class.relname = '/*REQUEST REMOVED*/' and pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null
> edu.umn.gis.mapscript.mapscriptJNI.layerObj_draw(Native Method)
> edu.umn.gis.mapscript.layerObj.draw(layerObj.java:472)
> fr.ird.remige.bean.MapFileBean$layerItemClass.draw(MapFileBean.java:617)
> fr.ird.remige.bean.MapFileBean.draw(MapFileBean.java:1105)
> REQUEST REMOVED was something like :
> g_carre5 from (select distinct g_carre5 from carre
> inner join date using (id_date)
> inner join country using (id_country)
> WHERE v_date BETWEEN 2000 AND 2001 AND _*l_country='France'*_
> group by g_carre5) as foo
> The previous request, which was working, was :
> WHERE v_date BETWEEN 2000 AND 2001 AND _*v_country=1*_
> _
> Table country :_
> id_country serial primary key
> v_country numeric(4)
> l_country varchar(12)
> And first line is id_country = 1, v_country = 1, l_country = France.
> One strange thing is that, when I am using a mapfile script on my
> computer (not on the server) and transform it into an image file
> with *shp2img* (shell command), both requests are working.
> Moreover, both requests are also working with SQL command, when
> logged into the database.
> In Java, the string containing the request is : "g_carre5 from
> (select distinct g_carre5 from carre inner join date using
> (id_date) inner join country using (id_country) WHERE v_date
> BETWEEN 2000 AND 2001 AND l_country=\'France\' group by g_carre5)
> as foo".
> I also tried to replace *\' *by *\"*, and the expected error
> /*column "France" does not exist*/ was reported, which shows that
> Libmapscript.so translated *\"* correctly.
> I do not understand why there is this quoting issue. Does somebody
> have ever dealt with something like that?
> Julien
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080827/4b7321ef/attachment.html
