[mapserver-users] howto draw amount of points features of one
layer depending on scale
Nils Zierath
nils.zierath at uni-bonn.de
Wed Aug 27 09:42:52 EDT 2008
Hi David,
your suggestion is similar to Jeff's?
How would I treat a point as lable? I haven't had any luck in displaying the points
with "TYPE ANNOTATION".
What would the syntax in the mapfile would look like to either treat a point as lable
or with "TYPE ANNOTATION"?
My mapfile currently looks like:
LAYER
NAME 'Field research locations'
DATA '../vector/gps/fieldresearch_complete'
STATUS default
TYPE point
#TYPE annotation
TRANSPARENCY 100
TOLERANCE 7
TOLERANCEUNITS pixels
UNITS kilometers
METADATA
END #METADATA
PROJECTION
END #PROJECTION
CLASSITEM 'StudyFocus'
#LABELITEM 'LableAnnot'
CLASS
NAME 'Research locations (all)'
#MINSCALEDENOM 1000000
STYLE
SYMBOL 'ttf_pin-sm'
SIZE 10
COLOR 255 180 0
ANGLE 345
END #STYLE
END #CLASS
END #LAYER
David Percy schrieb:
> If you treated them as labels when zoomed out (maxscale 50000 for
> example), then you could take advantage of the label colission features
> of mapserver to avoid overlaps.
> when zoomed in further you could have another layer (minscale 50000 for
> example) that shows all the detail...
> so you would have two layer definitions in this case...
> Cheers,
> Percy
> Nils Zierath wrote:
>> Dear list,
>> I got a layer with gps points. On the largest scale of my map the
>> symbols for points overlap and are not distinguishable from one
>> another since they are too close together.
>> Is it possible to tell mapserver to draw only that many of the
>> points/symbols that do not overlap, so that more points will be shown
>> the more I zoom into the map?
>> Thank you,
>> Nils
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
