[mapserver-users] Problems with TILEINDEX moving from
Mapserver 5.0 to 5.2 - solved
Robert Sanson
SansonR at asurequality.com
Thu Aug 28 20:49:49 EDT 2008
Hi Jeff
OK - I see that the Location values should be relative to TILEINDEX rather than Map file.
Solved.
Much appreciated,
Robert Sanson
>>> Jeff McKenna <jmckenna at gatewaygeomatics.com> 29/08/2008 12:38 p.m. >>>
There were some changes, but the old behavior should have been
maintained (http://trac.osgeo.org/mapserver/ticket/2369).
Maybe you should be more specific (what your SHAPEPATH parameter states,
as well as your index's LOCATION values are).
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
Robert Sanson wrote:
> Hi
> I have just installed ms4w v 2.2.8 with mapserver 5.2. My mapfile no
> longer seems to work for raster layers using a TILEINDEX. Other layers
> are displaying fine. Has there been any change that anyone knows of?
> Here is an typical raster layer entry:
> LAYER
> NAME nz1mtm
> GROUP "Toposcans"
> PROJECTION
> "init=epsg:2193"
> END
> TYPE RASTER
> DUMP TRUE
> STATUS ON
> TILEINDEX ../data/nztm/1mtm_index
> TILEITEM Location
> MAXSCALE 3000000
> MINSCALE 300000
> END
> Many thanks,
> Robert Sanson
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080829/595c6a6a/attachment-0001.html
