[mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
Justyna Lubkowski
J.Lubkowski at bom.gov.au
Thu Dec 4 00:33:17 EST 2008
Hi Steve,
Thanks for your reply and the tar ball with the shapefiles and map file.
I've tried your map file with the following test script.
#!/usr/bin/perl
use mapscript;
$req = new mapscript::OWSRequest( );
$req->setParameter( "SERVICE", "WMS" );
$req->setParameter( "VERSION", "1.1.0" );
$req->setParameter( "REQUEST", "GetCapabilities" );
$map = new mapscript::mapObj( "minimal_wms.map" );
$map->OWSDispatch( $req );
The error message I get is:
Can't call method "OWSDispatch" without a package or object reference at
./minimal_wms.pl line 14.
I'm pretty sure that setParameter has not set SERVICE, VERSION OR
REQUEST.
Any ideas?
Cheers - Justyna.
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Tuesday, 2 December 2008 8:24 AM
To: Justyna Lubkowski; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
Your mapfile doesn't look to meet the minimum configuration requirements
for WMS. For example, there is no projection information defined. I have
a minimal WMS config example that I've attached for reference purposes.
Steve
>>> On 11/26/2008 at 6:49 PM, in message
<29237876E2F56546975A098DC25F3D4A030AA211 at officeho2.bom.gov.au>,
"Justyna Lubkowski" <J.Lubkowski at bom.gov.au> wrote:
> Hi,
> I'm hoping someone can help, I've been trying to get Perl mapscript to
> work using a couple of examples from the "MapScript wrappers for WxS
> Services" page http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript
> Using python mapscript it works, when I run it on the command line I
> get xml output, however if I try doing the same using perl mapscript I
> get no xml output on the command line, I get errors telling me that I
> cannot set the SERVICE, VERSION or REQUEST parameters. I've included
> the python and perl scripts and their respective map files below. If
> I try using $req->loadParams() in the script, and pass the same
> parameters as part of the query string, then do a wget I get a zero
length file.
> Am I doing something wrong? Or is there a bug in perl mapscript?
> Cheers - Justyna.
> #!/usr/bin/python
> import mapscript
> req = mapscript.OWSRequest()
> req.setParameter( 'SERVICE', 'WMS' )
> req.setParameter( 'VERSION', '1.1.0' ) req.setParameter( 'REQUEST',
> 'GetCapabilities' )
> map = mapscript.mapObj( 'test.map' )
> map.OWSDispatch( req )
> with the following map file
> MAP
> SIZE 600 300
> EXTENT -180 -90 180 90
> IMAGECOLOR 180 180 250
> IMAGETYPE PNG
> UNITS DD
> WEB
> IMAGEPATH "/html/tmp/wms"
> IMAGEURL "/tmp/"
> METADATA
> OWS_ONLINERESOURCE "http://servername/test.py"
> END
> END
> LAYER
> NAME "coast_polygon"
> TYPE POLYGON
> STATUS DEFAULT
> DATA coast
> CLASS
> COLOR 231 220 189
> OUTLINECOLOR 198 134 0
> NAME "Coast "
> END
> END
> END
> I get the following errors using perl mapscript:
> cannot set wms parameter at ./test3.pl line 6.
> cannot set version parameter at ./test3.pl line 7.
> cannot set request parameter at ./test3.pl line 8.
> #!/usr/bin/perl -w
> use mapscript;
> $req = new mapscript::OWSRequest() or die "no request";
> $req->setParameter('SERVICE','WMS') or warn "cannot set wms parameter
> $req->setParameter('VERSION','1.1.1') or warn "cannot set version
> parameter $!";
> $req->setParameter('REQUEST','GetCapabilities') or warn "cannot set
> request parameter $!";
> $map = new mapscript::mapObj("test3.map") or die "no object";
> $map->OWSDispatch( $req ) or die "cannot dispatch";
> and its mapfile is
> MAP
> SIZE 600 300
> IMAGETYPE PNG
> UNITS DD
> WEB
> IMAGEURL "/tmp/"
> METADATA
> OWS_ONLINERESOURCE http://servername/test3.pl
> END
> END
> LAYER
> TYPE POLYGON
> STATUS DEFAULT
> DATA coast
> CLASS
> COLOR 231 220 189
> NAME "Coast "
> END
> END
> END
