[mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Thu Dec 4 07:41:09 EST 2008
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Justyna Lubkowski
> Sent: Thursday, 04 December 2008 00:33
> To: Steve Lime; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
> Hi Steve,
> Thanks for your reply and the tar ball with the shapefiles
> and map file.
> I've tried your map file with the following test script.
> #!/usr/bin/perl
> use mapscript;
> $req = new mapscript::OWSRequest( );
> $req->setParameter( "SERVICE", "WMS" );
> $req->setParameter( "VERSION", "1.1.0" ); $req->setParameter(
> "REQUEST", "GetCapabilities" );
> $map = new mapscript::mapObj( "minimal_wms.map" );
The mapfile can't be found. Try changing this line to:
$map = new mapscript::mapObj( "minimal_wms.map" ) or warn "mapfile
error: $!\n";
..and you'll see the error.
Try pointing to the mapfile fullpath?
> $map->OWSDispatch( $req );
> The error message I get is:
> Can't call method "OWSDispatch" without a package or object
> reference at ./minimal_wms.pl line 14.
> I'm pretty sure that setParameter has not set SERVICE,
> VERSION OR REQUEST.
> Any ideas?
> Cheers - Justyna.
> From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Sent: Tuesday, 2 December 2008 8:24 AM
> To: Justyna Lubkowski; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
> Your mapfile doesn't look to meet the minimum configuration
> requirements for WMS. For example, there is no projection
> information defined. I have a minimal WMS config example that
> I've attached for reference purposes.
> Steve
> >>> On 11/26/2008 at 6:49 PM, in message
> <29237876E2F56546975A098DC25F3D4A030AA211 at officeho2.bom.gov.au>,
> "Justyna Lubkowski" <J.Lubkowski at bom.gov.au> wrote:
> > Hi,
> > I'm hoping someone can help, I've been trying to get Perl
> mapscript to
> > work using a couple of examples from the "MapScript
> wrappers for WxS
> > Services" page http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript
> > Using python mapscript it works, when I run it on the
> command line I
> > get xml output, however if I try doing the same using perl
> mapscript I
> > get no xml output on the command line, I get errors telling
> me that I
> > cannot set the SERVICE, VERSION or REQUEST parameters.
> I've included
> > the python and perl scripts and their respective map files
> below. If
> > I try using $req->loadParams() in the script, and pass the same
> > parameters as part of the query string, then do a wget I get a zero
> length file.
> > Am I doing something wrong? Or is there a bug in perl mapscript?
> > Cheers - Justyna.
> > #!/usr/bin/python
> > import mapscript
> > req = mapscript.OWSRequest()
> > req.setParameter( 'SERVICE', 'WMS' )
> > req.setParameter( 'VERSION', '1.1.0' ) req.setParameter( 'REQUEST',
> > 'GetCapabilities' )
> > map = mapscript.mapObj( 'test.map' )
> > map.OWSDispatch( req )
> > with the following map file
> > MAP
> > SIZE 600 300
> > EXTENT -180 -90 180 90
> > IMAGECOLOR 180 180 250
> > IMAGETYPE PNG
> > UNITS DD
> > WEB
> > IMAGEPATH "/html/tmp/wms"
> > IMAGEURL "/tmp/"
> > METADATA
> > OWS_ONLINERESOURCE "http://servername/test.py"
> > END
> > END
> > LAYER
> > NAME "coast_polygon"
> > TYPE POLYGON
> > STATUS DEFAULT
> > DATA coast
> > CLASS
> > COLOR 231 220 189
> > OUTLINECOLOR 198 134 0
> > NAME "Coast "
> > END
> > END
> > END
> > I get the following errors using perl mapscript:
> > cannot set wms parameter at ./test3.pl line 6.
> > cannot set version parameter at ./test3.pl line 7.
> > cannot set request parameter at ./test3.pl line 8.
> > #!/usr/bin/perl -w
> > use mapscript;
> > $req = new mapscript::OWSRequest() or die "no request";
> > $req->setParameter('SERVICE','WMS') or warn "cannot set wms
> parameter
> > $req->setParameter('VERSION','1.1.1') or warn "cannot set version
> > parameter $!";
> > $req->setParameter('REQUEST','GetCapabilities') or warn "cannot set
> > request parameter $!";
> > $map = new mapscript::mapObj("test3.map") or die "no object";
> > $map->OWSDispatch( $req ) or die "cannot dispatch";
> > and its mapfile is
> > MAP
> > SIZE 600 300
> > IMAGETYPE PNG
> > UNITS DD
> > WEB
> > IMAGEURL "/tmp/"
> > METADATA
> > OWS_ONLINERESOURCE http://servername/test3.pl
> > END
> > END
> > LAYER
> > TYPE POLYGON
> > STATUS DEFAULT
> > DATA coast
> > CLASS
> > COLOR 231 220 189
> > NAME "Coast "
> > END
> > END
> > END
