[mapserver-users] Strategies for creating Google Map tiles...
Roger André
randre at gmail.com
Thu Dec 4 11:51:12 EST 2008
Hi John,
I've had good success with Option 1, but I'm not sure I understand all of
the conditions you've mentioned. I assume that you intend to display these
tiles in a Google Maps mashup when you're done? If so, using TileCache's
tilecache_seed.py would allow you to pre-generate the tiles using Mapserver
initially, and then display them in the map - without ever calling on
Mapserver again. The major advantage I see to this method is that Mapserver
can aggregate all of the separate layers and display them in a common
projection.
Good luck,
Roger
On Thu, Dec 4, 2008 at 7:07 AM, John Jameson <jjmapping at gmail.com> wrote:
> I need to make tiles compatible with Google maps out of this mess. The
> outcome needs to be the typical pyramid of tiles where each detailed zoom
> level has 4x the number of tiles than the level above.
> Here are the things I've considered strategy-wise:
> 1. Combine everything into a single map file and then let MapServer serve
> the tiles (through TileCache). I can then go through the area of data I'm
> interested in and collect the tiles and save them. The super advantage of
> this strategy is that I can test it by having it serve the tiles live.
> It'll be slower than having them pre-computed and that isn't ultimately
> acceptable because I'll need offline use of the tiles and won't have
> MapServer. Still, it allows for great testing before the tile collection
> begins. The disadvantage is that I fear I'll run out of space with
> hundreds
> of raster maps and another hundred shapefiles (each with 20-30 layers). I
> fear I'd have to re-gen MapServer with all of the layers needed. Back on
> the plus side, it seems like MapServer will "quilt" the maps together
> nicely. This strategy has me scared about resource size and speed needed.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081204/f3dcd6c4/attachment.html
