[mapserver-users] MapServer 5.2.1 Released
Stephan Holl
stephan.holl at intevation.de
Thu Dec 4 13:53:31 EST 2008
"Steve Lime" <Steve.Lime at dnr.state.mn.us>, [20081201 - 14:14:50]
> Hi all: The MapServer PSC has just released version 5.2.1. This new
> release contains no additional functionality but addresses a number
> of issues identified since the 5.2.0 release. A list of fixes is
> included at the end of this message. The full change log can be
> viewed online at:
> http://mapserver.gis.umn.edu/download/current/HISTORY.TXT
> The source package is available in the MapServer downloads page:
> Precompiled binaries should be available shortly at the usual
> locations (also linked from the download page above).
The OpenSuSE.repositorys provide RPMs for MS 5.2.1 for the following
versions:
* SLE_10 (i586/x86_64)
* openSUSE_10.2 (i586/x86_64)
* openSUSE_10.3 (i586/x86_64)
* openSUSE_11 (i586/x86_64)
You can find them here (or include the repo into yast):
http://download.opensuse.org/repositories/Application:/Geo/
Best regards
Stephan Holl
> Version 5.2.1 (2008-12-01)
> * Exposed PIXELS value via URL configuration
> * Add Support for SLD TextSymbolizer HALO and ANGLE (#2806)
> * Fix crash when an invalid bbox filter is used (#2805)
> * raster query fix for tileindex with relative paths (#2722)
> * Fix for the access violation caused by msMSSQL2008LayerGetShape
> (#2795)
> * Fixed msMSSQL2008LayerGetItems to retrieve the column names
> properly (#2791)
> * Prevent from calling msMSSQL2008CloseConnection from
> msMSSQL2008LayerClose causing memory corruption issues (#2790)
> * fix some integer rounding errors in the agg line offseter (#2659)
> * fix a bug with shapes with duplicate end points. was causing NaNs
> in the angle follow placement code (#2695)
> * memory leak in msInsertLayer, from Ned Horning (#2784)
> * legend keyimage resampling with agg (#2715)
> * tileindexed rasters when DATA is manipulated via mapscript work
> (#2783)
> * PHP: add priority attribute to the label object (#2782)
> * Fixed bug when QUERYMAP hilite color is set and the shape's color
> in a layer is from a data source (#2769)
> * PHP paste image should also work with AGG (#2682)
> * Correct allocation error in mapmssql2008.c (#2768)
> * Removed comma to correct WCS 1.1 Coverages formatting in payload
> directory. (#2764)
> * Correct bug when LABEL_NO_CLIP in combination with minfeaturesize
> (#2758)
> * Fix a label size computation for AGG bug when scalefactor is used
> (#2756)
> * Got rid of misleading errors about OWS SERVICE not being compiled
> in when a OWS request is sent that includes mode=map (or other mode
> value different from ows)(#2747)
> * Fixed a memory leak associated with not deleting the lexer buffer
> before parsing certain types of strings. (#2729)
> * Masking the out-of-range characters to avoid the crash in the AGG
> renderer (#2739)
> * AGG: fix pixmap symbols not drawing if no color was specified
> (#2736)
> * Accept WMS requests in which the optional SERVICE param is missing.
> A new test was incorrectly added in 5.2.0 that resulted in the error
> "Incomplete WFS request: SERVICE parameter missing" when the SERVICE
> parameter was missing in WMS requests in which the SERVICE param is
> optional (#2737)
> * SLD: when creating well known symbols on the fly the pen-up value
> used should be -99.
> * Support reading projection parameter for OFC filters (#2712)
> * Stop configure execution with an error if path to one of the
> -config scripts is invalid (#2710)
> * Fixed the configure script: failed to detect php5 on ubuntu.
> (#2365)
> mapserver-users at lists.osgeo.org
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081204/2f9edf1d/signature.bin
