[mapserver-users] Tileindex doesn't draw when changes mapserver
version
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Dec 5 10:35:49 EST 2008
José Angel Rodríguez Leyva wrote:
> Hi,
> I´m using a set of separated DGN rectangular maps, joined together in a
> single tileindex shape file, in many projects and different mapserver
> versions and always works fine. Some days ago I tried to upgrade to the
> 2.2.7 Mapserver 4 Windows (ms4w) version, with MapServer 5.0.2 and GDAL
> 1.5.0 releases and now all tileindex layer drawings are empties (layer
> works in 5.0.0 ms version). There's no error messages or any
> mis-function with mapserver excepts that produce nothing. The output
> files are SWF flash movies. There's 74 DGN files and anyone is drawn if
> it is added in the mapfile as individual layer.
> I think it's possible there is a bug error in somewhere, because how the
> map couldn't draw correctly just changing to a new server subversion.
> greetings
> josé a.r.
José,
There was some changes to the how MapServer treats tileindexes after the
5.0.2 release. Can you upgrade to the latest MS4W (with MapServer
5.2.1) and try again?
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
