[MAPSERVER-USERS] Problems with scalebar embedding and java mapscript
maurosa
maurosa at IOL.IT
Mon Dec 8 14:00:52 EST 2008
Hi list
I am experiencing problems with scalebar embedding
after version 5.02 using java mapscript.
Changing map extent, does not change scalebar values.
Version 5.02 works properly.
The error happens with version 5.20 and 5.21.
If scalebar usage is changed after version 5.02,
I thank you for any suggestion.
Mauro
This is a simple java mapscript program to reproduce the error:
System.loadLibrary("mapscript");
//first extent: scalebar values are correct
mapObj map = new mapObj("mymap.map");
imageObj img = map.draw();
img.save("mymap1.jpeg", map);
//second extent: scalebar values are wrong
//and are frozen to those of first image
map.setExtent(300000, 4800000, 900000, 5200000);
img = map.draw();
img.save("mymap2.jpeg", map);
//from this point on, changing map extent does
//not change the original scalebar values any more
The following is mymap.map:
MAP
STATUS ON
EXTENT 20000 4030000 1650000 5250000
SIZE 700 500
SYMBOLSET "symbols/symbols.sym"
FONTSET "fonts/fonts.list"
IMAGETYPE JPEG
IMAGECOLOR 255 255 255
UNITS METERS
PROJECTION
"init=epsg:32632"
END
OUTPUTFORMAT
NAME "JPEG"
MIMETYPE "image/jpeg"
DRIVER "AGG/JPEG"
EXTENSION "jpg"
IMAGEMODE "RGB"
TRANSPARENT FALSE
FORMATOPTION "QUALITY=95"
END
SCALEBAR
STATUS embed
SIZE 200 3
UNITS kilometers
BACKGROUNDCOLOR 120 120 120
COLOR 200 200 200
STYLE 0
POSTLABELCACHE true
LABEL
COLOR 0 0 90
SIZE small
END
END
LAYER
NAME "MYLAYER"
STATUS ON
DATA "GEOMETRY FROM MYLAYER USING UNIQUE CODE SRID 8307 RELATE"
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "user/password at sid"
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
OUTLINECOLOR 0 0 255
END
END
END
END
View this message in context: http://www.nabble.com/Problems-with-scalebar-embedding-and-java-mapscript-tp20901440p20901440.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
