[mapserver-users] Difference in appearance between "mode=map"
and WMS
Julien-Samuel Lacroix
jlacroix at mapgears.com
Mon Dec 8 15:25:14 EST 2008
I guess would be that the WMS use non-square pixels. So if your BBOX x/y
(rectangle in your case) doesn't match you WIDTH/HEIGHT ratio (square
in your case) the map will appear stretched. MapServer will actually
stretch the map to fit the extent in the WIDTH/HEIGHT.
The mode=map don't do that. If your extent doesn't have the same ratio,
it adds some degree in your extent to fit the size.
Make sure your BBOX and EXTENT are a square in your requests and retry
Julien
Roger André wrote:
> Hi All,
> I think I'm having an instance of cranial flatulation, but maybe not.
> Hopefully you can set me straight.
> I need to create an image with Mapserver using mapscript that I can then
> georeference manually and use in another application. It needs to look
> exactly the same as the image I can already generate via a WMS call that
> looks like this:
> http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/hydro/hydro.map
> &SERVICE=WMS
> &version=%221.1.1%22
> &REQUEST=GetMap
> &LAYERS=imagery
> &STYLES=&BBOX=-125,39,-108,54
> &WIDTH=600
> &HEIGHT=600
> &FORMAT=png
> &SRS=epsg:4326
> I'm testing my mapscript parameters using a simple "mode=map" call to
> Mapserver, and the results I'm getting so far don't match the appearance
> of the WMS output at all. My mapfile has the following extent and
> projection info in it:
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT -125.0 39.0 -108.0 54.0
> SIZE 600 600
> In addition to the mapfile projection specification, I am also
> specifying the same projection info in each of my LAYERS as well.
> Is it possible to do what I'm trying to accomplish here?
> Thanks,
> Roger
> mapserver-users at lists.osgeo.org
Mapgears
http://www.mapgears.com/
