[mapserver-users] Scalebar vs Numeric scale
Robert Sanson
SansonR at asurequality.com
Mon Dec 8 19:45:55 EST 2008
Have you checked the RESOLUTION parameter. I think the default is 72 (based on dots per inch of older computer monitors). Maybe you should change this to 96 dpi, or whatever you monitor resolution is:
# default output image dimensions
SIZE 512 512
RESOLUTION 96
regards,
Robert Sanson
>>> "Rui Gomes" <ruijgomes at gmail.com> 9/12/2008 1:10 p.m. >>>
Hi...
I have a small problem with the scale. The numeric scale and the
scalebar don match. In the firth is 1/150.000 but measuring the
second is 1/200.000. Someone have any clue?
Thanks
PS: I don't change any image size but i change the map size by the URL.
Rui Gomes
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081209/f01bbe05/attachment.html
