[mapserver-users] How to make MapServer WMS super fast?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Dec 12 13:45:17 EST 2008
I don't believe pre-cached tiles would fulfill specifications but it need to be basic WMS. I will try to get fast-CGI running and make some new measurements then.
-Jukka Rahkonen-
Roger André wrote:
> I think serving pre-cached tiles with TileCache running under FastCGI should
> improve your response times considerably.
Roger
PS - Give send an update if you try any of these.
On Fri, Dec 12, 2008 at 8:00 AM, Léveillé, James <
James.Leveille at mtq.gouv.qc.ca> wrote:
> Here is a message published by Alexandre Dubé a few weeks ago - helpfull
> Here's how to install and setup fastCGI with Apache 2.2.8 contained in
> the MS4W 2.2.7 version.
> 1- MS4W 2.2.7 contains a MapServer compiled to support FastCGI so
> nothing needs to be done there.
> 2- But, Apache 2.2.8 that comes with MS4W 2.2.7 doesn't include the
> mod_fcgi module. This module can be dowloaded at
> *http://www.apachelounge.com/download/*<http://www.apachelounge.com/download/>... Take the
> mod_fcgid-2.2a-w32.zip which will work with Apache 2.2.8.
> 3- Copy mod_fcgid.so to your apache/modules folder
> 4- Install the Visual C++ 2008 Redistributable Package (the binary is
> build with VC 2008). Download and install, if it isn't already done,
> from:
> www.microsoft.com/downloads/details.aspx?FamilyID=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
> 5- Modify your /ms4w/Apache/conf/httpd.conf
> a) Add :
> LoadModule fcgid_module modules/mod_fcgid.so
> b) Add :
> ScriptAlias /cgi-bin/ "/ms4w/Apache/cgi-bin/"
> ScriptAlias /fcgi-bin/ "/ms4w/Apache/cgi-bin/"
> c) Remove :
> <Directory "/ms4w/Apache/cgi-bin">
> AllowOverride All
> Options None
> Order allow,deny
> Allow from all
> </Directory>
> d) Add :
> <Location "/cgi-bin">
> Options None
> Order allow,deny
> Allow from all
> </Location>
> e) Add :
> <Location "/fcgi-bin">
> # The following line activates the fastCGI script to all files
> in location
> SetHandler fcgid-script
> Options None
> Order allow,deny
> Allow from all
> </Location>
> f) Add :
> <IfModule fcgid_module>
> IPCCommTimeout 60
> IdleTimeout 60
> DefaultMinClassProcessCount 2
> DefaultMaxClassProcessCount 20
> DefaultInitEnv PROJ_LIB "c:/ms4w/proj/nad/"
> DefaultInitEnv PATH
> "c:/ms4w/Apache/cgi-bin;c:/WINDOWS/system32;c:/WINDOWS;c:/WINDOWS/System32/Wbem;"
> DefaultInitEnv windir "c:/WINDOWS"
> DefaultInitEnv SystemRoot "c:/WINDOWS"
> DefaultInitEnv SystemDrive "c:"
> DefaultInitEnv GDAL_DATA "c:/ms4w/gdaldata"
> DefaultInitEnv GDAL_DRIVER_PATH "c:/ms4w/gdalplugins"
> DefaultInitEnv TMP "c:/ms4w/tmp"
> DefaultInitEnv TEMP "c:/ms4w/tmp"
> </IfModule>
> 6- Restart Apache : /ms4w/apache-restart.bat
> 7- In your mapfile, set a PROCESSING directive to tell FastCGI to cache
> the connections and layer information on all layers for which connection
> caching is desired - ie. all slow layers.
> a) Add :
> PROCESSING "CLOSE_CONNECTION=DEFER"
> 8- Now you can load your map using either normal CGI or FastCGI :
> a) CGI :
> *http://host:port/cgi-bin/mapserv.exe*<http://host:port/cgi-bin/mapserv.exe>?...
> b) fastCGI :
> *http://host:port/fcgi-bin/mapserv.exe*<http://host:port/fcgi-bin/mapserv.exe>?...
> That way, your original cgi-bin folder wont be affected by fastCGI
> unless you use the modified url with "fcti-bin" which is the alias you
> added to your httpd.conf file at 5b).
> Special thanks to Jeff McKenna and Daniel Morissette who helped me a lot
> with this.
> ______________________________________________________
> *JAMES LÉVEILLÉ
> *Service des systèmes de Mission
> Direction des technologies de l'information
> Ministère des Transports du Québec
> 5833, boul. Pierre-Bertrand, 2ième étage
> Québec (Québec) G2K 1K7
> Téléphone: (418) 380-2005 poste 227
> Télécopieur: (418) 644-6653
> james.leveille at mtq.gouv.qc.ca
> -----Message d'origine-----
> *De :* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *De la part de* Rahkonen Jukka
> *Envoyé :* 12 décembre 2008 10:39
> *À :* Marcelo Oliveira; mapserver-users at lists.osgeo.org
> *Objet :* Re: [mapserver-users] How to make MapServer WMS super fast?
> Hi,
> Thanks, I will try Fast CGI. Are there some simple enough document for a
> ms4w users about how to turn the system to use Fast CGI?
> -Jukka-
> *Lähettäjä:* Marcelo Oliveira [mailto:moliveira at GEOSTATS.com]
> *Lähetetty:* 12. joulukuuta 2008 17:05
> *Vastaanottaja:* Rahkonen Jukka; mapserver-users at lists.osgeo.org
> *Aihe:* RE: [mapserver-users] How to make MapServer WMS super fast?
> Try using Fast CGI, it should improve your latency problem you are
> seeing. It is also possible that using other raster formats could help.
> Good luck! M
> Marcelo Simas Oliveira
> GeoStats LP
> 530 Means St., Ste. 310
> Atlanta, Georgia 30318
> (404) 588-1004
> www.geostats.com
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Rahkonen Jukka
> *Sent:* Friday, December 12, 2008 10:01 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] How to make MapServer WMS super fast?
> Hi,
> Are there any effective tricks for making MapServer to Top-Fuel class? We
> have now a typical ms4w installation on a rather good server platform with
> SCSI drives and 2 four-core processors running on Windows 2003 server. Our
> images are tiled, uncompressed geotiffs with overviews, vector sample data
> set is shapefile with shptree index. I have a shortened epsg file and my
> mapfile is extra short. Bandwith is not the limit. We are getting out now
> about 450 orthoimage pictures per minute (size 500 by 500 pixels) and 550
> pictures from the vector layer in png24 image format. I consider that
> rather good, but we are required to reach 20 images per second, thus 1200
> images per minute or 0.05 seconds per image. I wonder if anybody has tuned
> MapServer that far.
> I am willing to try however exotic solutions to reach the 20 WMS output
> images/second goal if somebody could suggest me what to try next. In our
> system there seems to be about 0.1 second ballast with WMS getMap requests
> and I cannot get any faster response even if I try with on empty data layer
> with nothing to render. Have anybody tried to keep mapfile, epsg-file or
> even tileindex files in RAM drive?
> Having about 20 parallel users seems to be optimal for our server and if
> I drive just WMS getCapabilities request against my mapfile I can get about
> 1300 responses per minute. That leads me to think that 1200 rendered images
> per minute might be possible to reach with optimal set-up.
> -Jukka Rahkonen-
