[mapserver-users] wfs data conversion with ogr2ogr?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Dec 15 03:50:06 EST 2008
For me it looks like that gml does not contain actual feature coordinates, but the bounding box of the feature. In this case feature is probably a point and feature coordinates and bbox are the same but perhaps a point should be introduced as a point as well? just thinking, I do not understand much gml.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Knut Behrends
> Lähetetty: 15. joulukuuta 2008 10:34
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] wfs data conversion with ogr2ogr?
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> I have received data from a WFS that was returned in this format:
> (Sample feature member)
> <gml:featureMember>
> <featureSet_704 fid="featureSet_704-feature_1732">
> <gml:boundedBy>
> <gml:Box>
> <gml:coord>
> <gml:X>4436682.0</gml:X>
> <gml:Y>5783076.0</gml:Y>
> </gml:coord>
> <gml:coord>
> <gml:X>4441086.0</gml:X>
> <gml:Y>5786776.0</gml:Y>
> </gml:coord>
> </gml:Box>
> </gml:boundedBy>
> <GEOM_ID>1732</GEOM_ID>
> <NAME>Marienborn</NAME>
> </featureSet_704>
> </gml:featureMember>
> ogrinfo can parse the file:
> ogrinfo SA_PLACES.gml
> Had to open data source read-only.
> INFO: Open of `SA_PLACES.gml'
> using driver `GML' successful.
> 1: featureSet_704
> ogr2ogr can also convert the file to, say, Esri Shapefile.
> There isI must assign a source SRS and a target SRS and force
> a source geometry type.
> INFO: Open of `out/featureSet_704.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: featureSet_704
> Geometry: Line String
> Feature Count: 100
> Extent: (0.000000, 0.000000) - (0.000000, 0.000000) Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_1984",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]]
> GEOM_ID: Real (11.0)
> OGRFeature(featureSet_704):0
> GEOM_ID (Real) = 1732
> NAME (String) = Marienborn
> After successful conversion, however, only the GEOM_ID and
> the NAME are exported. The spatial information is ignored
> lost during the conversion.
> Maybe it's in the wrong format, but it is obviously present
> in the GML fragment above. What can I do to convert the
> spatial information that is contained in the <X> and <Y> elements?
> Knut
> ______________________________________________________________
> ______________
> Knut Behrends Phone: +49 (0) 331 288 1688
> Potsdam 14473 KeyID: 0xF22CACEF (PGP
> Public Key)
> ______________
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iEYEARECAAYFAklGFmYACgkQcfWHNfIsrO9NNACfTwBojDKZ0MU3J/yVUBiof5JP
> P28AnRStqwySPcQ9gM+hjAgQBNZYRZz4
> =Eane
> -----END PGP SIGNATURE-----
