[mapserver-users] Please help me
Dan Little
danlittle at yahoo.com
Mon Dec 15 10:58:52 EST 2008
Sounds like you have a multifaceted problem.
Is SELINUX are requirement of your environment? If not ... you might just want to g'head and disable it. Before people get on my back, I know it's bad to disable SELINUX to fix problems ... but it's a good first step to diagnose if it is the root of the problem. Then go back, fix your labels, and re-enable SELINUX. As SELINUX is the first error you see I'd suggest starting there.
Also, what is your application actually doing? If you're doing a join against a large shapefile or doing a big database operation you may need to look at optimizing the database queries.
The picture thing should probably come AFTER fixing some of the other problems... 'course that's where my knowlege and assistance runs a little short... I haven't georeferenced any rasters in a while.
To: mapserver-users at lists.osgeo.org
Sent: Monday, December 15, 2008 7:39:05 AM
Subject: [mapserver-users] Please help me
Hello everyone...
I have one serious problem. My application is not running. Suddenly It happens.I dont know why?? Actually Problem is that If I run my program by simple typing the url then my system becomes hang(not hang actually it becomes to much slow).If I run http then my cpu load average is becoming 12.34 like that..(running the top command)but it should to be less than 2 always.And either Firefox or httpd is taking 99% cpu. And one more thing is that I got one message that Selinux is preventing the mislabelled files. If I disable Selinux then also my program is not running..Not running means it is coming after a long time. If I increased my server time out option to 60 from 30(default located in php.ini)then it is eventually coming after a long period.
One More thing is that I have one image having extent 0,0,234,345.Now suppose I have latitude and longitude information of 4 corners of that picture. Now I want to change the extent of that picture .Is it possible??
Usually We define the extent of map .it means that output extent. if I include projection lat long and give the lat long extent(which is not embeded with that input picture) the picture will come or not......because the extent should to be output extent.
Actually we should to have raster data not image ..but suppose we have raster image as input, and o/p will be the same image.....
please help me.............help me plz...........
Thanks
Amiya
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081215/c6348b5f/attachment-0001.html
