[mapserver-users] Blank image after map request
RODIER BATISSE, ALEXANDRE
alexandre.rodier at carm.es
Wed Dec 17 01:28:29 PST 2008
Hi Jeff and all others than help me.
I tried all your advice and i changed this tips:
* I set STATUS layer tag to DEFAULT
* I changed wms_onlineresource tag to "http://localhost/cgi-bin/mapserv?map=/ms4w/Apache/htdocs/map/mosaico.map&"
* I checked EXTENT tag to correct extents
* I changed "wms_latlongbounding" layer tag to the correct extents
* I checked gdalinfo for both mosaico.ecw and mosaico.tif image files, and this is the result:
C:\ms4w\tools\gdal-ogr>gdalinfo c:\ms4w\Apache\htdocs\raster\mosaico.ecw
Driver: ECW/ERMapper Compressed Wavelets
Files: c:\ms4w\Apache\htdocs\raster\mosaico.ecw
Size is 302480, 316380
Coordinate System is `'
Origin = (556560.000000000000000,4293110.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Corner Coordinates:
Upper Left ( 556560.000, 4293110.000)
Lower Left ( 556560.000, 4134920.000)
Upper Right ( 707800.000, 4293110.000)
Lower Right ( 707800.000, 4134920.000)
Center ( 632180.000, 4214015.000)
Band 1 Block=302480x1 Type=Byte, ColorInterp=Red
Overviews: arbitrary
Band 2 Block=302480x1 Type=Byte, ColorInterp=Green
Band 3 Block=302480x1 Type=Byte, ColorInterp=Blue
C:\ms4w\tools\gdal-ogr>gdalinfo c:\ms4w\Apache\htdocs\raster\mosaico.tif
Driver: GTiff/GeoTIFF
Files: c:\ms4w\Apache\htdocs\raster\mosaico.tif
Size is 33910, 31638
Coordinate System is:
PROJCS["UTM Zone 30, Northern Hemisphere",
GEOGCS["ETRS89",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-3],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Pixel Size = (5.000000000000000,-5.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 556560.000, 4293110.000) ( 2d20'55.64"W, 38d47'5.69"N)
Lower Left ( 556560.000, 4134920.000) ( 2d21'40.71"W, 37d21'33.38"N)
Upper Right ( 726110.000, 4293110.000) ( 0d23'52.18"W, 38d45'27.90"N)
Lower Right ( 726110.000, 4134920.000) ( 0d26'52.05"W, 37d20'0.44"N)
Center ( 641335.000, 4214015.000) ( 1d23'20.00"W, 38d 3'46.30"N)
Band 1 Block=33910x1 Type=Byte, ColorInterp=Red
Band 2 Block=33910x1 Type=Byte, ColorInterp=Green
Band 3 Block=33910x1 Type=Byte, ColorInterp=Blue
It likes ok, but gdalinfo does not return coordinate system data for ecw image, when i changed ecw header info to ETRS89 and NUTM30.
* I tried shp2img with both ecw and tif images, and in both cases the result is a 800x500 blank image.
* I tried getcapabilities with this url: http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/map/mosaico.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
And it returnsme file in attached.
And finally, I tried Getmap with http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/map/mosaico.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&LAYERs=mosaico&SRS=EPSG:25830&bbox=556560,4134920,707800,4293920&format=image/png&width=800&height=500 and it returns 800x500 balnk image.
Conclusion: I don't know what i can also do.
Alexandre Rodier
Asistencia Técnica del SIGA
Servicio de Información e Integración Ambiental
Dirección General de Patrimonio Natural y Biodiversidad
Consejería de Agricultura y Agua.
c/ Arquitecto Emilio Piñero, 1 Entresuelo C
30.007 Murcia
Tel. 968246272
Correo-e: alexandre.rodier at carm.es
http://www.carm.es/medioambiente
-----Mensaje original-----
De: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Jeff McKenna
Enviado el: miércoles, 17 de diciembre de 2008 0:10
Para: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Blank image after map request
RODIER BATISSE, ALEXANDRE wrote:
> Hi everyone,
> I am begining with mapserver for windows and i have this problem:
> Mapserver work (theorycally) fine, because
> http://localhost/cgi-bin/mapserv.exe request in web navigator answer "No
> query information to decode. QUERY_STRING is set, but empty".
> I have a .map file in c:\ms4w\Apache\htdocs\map\ directory. (I put it in
> anex).
> But when a try to make a map request mapserver give a blank image
> (800x500 pixel)
> Whyyyyyyy!!!
I would also start with creating a valid map image with the shp2img
utility
(http://mapserver.gis.umn.edu/docs/reference/utilityreference/shp2img)
and once that works move to debugging your application (or request).
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081217/98494352/attachment.htm>
Type: application/octet-stream
Desc: getcapabilities.1&REQUEST=GetCapabilities
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081217/98494352/attachment.obj>
More information about the MapServer-users
