[mapserver-users] can we use variable in map file
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Fri Dec 19 06:44:46 EST 2008
You have to create empty mapfile using point type and call the_geom
form table .access data from database based on variables.For that you have
to write code in your programming language. Exp C# etc.
Thanks
Venkat.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of muzaffar
hussain
Sent: Friday, December 19, 2008 2:59 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] can we use variable in map file
hi all
can we use variable in POINTS of map file.for example
POINTS variable,variable
usually we use constant like this
POINTS 12,13
variable should get from database
any one who have any idea or example code pls send it to me.
thanks in advance
muzaffar
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081219/8f2a2051/attachment.html
