[mapserver-users] want plot dynamic points in map
muzaffar hussain
mhd.muzaffar at gmail.com
Sat Dec 20 02:05:29 EST 2008
hi all
i am doing project in vehicle tracking system.wat i want is
ploting dynamic points in the map.
if point is static means i can able to plot in particular location,my map
file is mention blow
*LAYER
NAME 'gps_point'
STATUS DEFAULT
TYPE POINT
FEATURE
# This is where you specify position on the map - using a default value
POINTS 0 0 END
END
CLASS
STYLE
SYMBOL "marker"
END
END
END
SYMBOL
NAME "marker"
TYPE PIXMAP
IMAGE "C:\ms4w\apps\ka-map-1.0\htdocs\images\bus.gif"
#TRANSPARENT 8
END*
in the above map file one statement *POINTS 0,0* is there , i am adding
static image (bus)in the map,
i want to add dynamic object in the map,that is current location of vehicle
in the map,i should take the longitude and latitude from database.
for example
*POINTS longitude,latitude*
if anybody is having the sample code,or come across this kind of
issue,please help me out from this,for the past 1 month i am trying to do
this,but i am not getting any resource for this.
please help me out from this.
thanks in advance
muzaffar
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081220/499f2abe/attachment.html
