[mapserver-users] getting error
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Dec 20 11:51:22 EST 2008
muzaffar hussain wrote:
> hi
> first i have created table in *mysql *as *testdata *which have four
> fields*(areaID,x,y,sampleValue)*
> then i have created *aqidata.ovf* which have following code mention below
> *<OGRVRTDataSource>
> <OGRVRTLayer name="aqidata">
> <SrcDataSource>MYSQL:aqiTest,user=uuuuu,password=ppppp,host=192.170.1.100,port=3306,tables=testdata</SrcDataSource>
> <SrcSQL>SELECT areaID, x, y, sampleValue FROM testdata</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>*
> then i have execute this .ovf in command line as follows
> *C:\ms4w\tools\gdal-ogr>ogrinfo aqidata.ovf
> ERROR 4: Update access not supported for VRT datasources.
> Had to open data source read-only.
> INFO: Open of `aqidata.ovf'
> using driver `VRT' successful.
> 1: aqidata (Point)*
> then i have created map file as follows
> *LAYER
> NAME "MyAqi"
> STATUS DEFAULT
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "aqidata.ovf"
> DATA "aqidata"
> CLASS
> NAME "MyClass"
> STYLE
> SYMBOL 'circle'
> SIZE 15
> COLOR 0 255 0
> END
> END
> END
> #Circle symbol
> SYMBOL
> NAME 'circle'
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> END
> *after that if i try to execute this map file means its showing the error
> C:\ms4w\tools\mapserv>shp2img -m ogr.map -o test.png
> msDrawMap(): Image handling error. Failed to draw layer named 'MyAqi'. <br>
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `MyAqi'. Fi
> le not found or unsupported format. <br>**
> please help me out from this ,where i have done a mistake
> thanks in advance
> muzaffar
> On Fri, Dec 19, 2008 at 8:25 PM, Fawcett, David
> <David.Fawcett at state.mn.us <mailto:David.Fawcett at state.mn.us>> wrote:
> Muzaffar,
> I think that we would have to see the text from your map file to
> figure this out.
> What format is your data in? (Based on the name, I have a guess
> that it is possible that you are using MySQL and following the HowTo
> that I wrote a long time ago...)
> If you are using MySQL, it could be that your MapServer binary was
> not compiled with a version of ogr that supports MySQL input. What
> do you get when you type mapserv -v ?
> We definitely need more info to help you.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [mailto:mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>] *On Behalf Of
> *muzaffar hussain
> *Sent:* Thursday, December 18, 2008 11:39 PM
> *To:* mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> *Subject:* [mapserver-users] getting error
> hi
> i am getting the following error if i am executing *"shp2img
> -m ogr.map -o test.png"*
> *msDrawMap(): Image handling error. Failed to draw layer named
> 'MyAqi'. <br>
> layer `MyAqi'. Fi
> please help out from this.
> thanks in advance
> muzaffar
I don't see any reference to you creating an ODBC connection to your
table, as in
http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
I would try those steps listed in that page.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
