[mapserver-users] ArcSDE 9.3 Raster Mapfile problem
marcusvcs
marcusvcs at gmail.com
Mon Dec 22 05:21:06 EST 2008
I'm trying to view a raster which is in ArcSDE 9.3 with the mapfile below:
MAP
NAME "RGB_2004"
#EXTENT -76.551793 -35.926191 -29.02357 8.997746
#EXTENT 503299.214 8027516.529 513375.214 8037593.529
EXTENT 8156335.197 450704.114 8202932.697 511209.614
FONTSET "c:\ms4w\apache\htdocs\i3geo/symbols/fontes.txt"
#-- retângulo envolvente geral da aplicação
IMAGETYPE PNG #-- output image type
SIZE 400 300 #-- largura x altura
STATUS ON
CONFIG "MS_ERRORFILE" "C:/ms4w/tmp/ms_error.txt"
DEBUG 5
UNITS DD #-- unidade do sistema de coordenadas de saída
WEB
METADATA #-- definições para habilitar o modo servidor WMS
"wms_title" "MapServer" #-- título do servidor
"wms_onlineresource"
"http://localhost/cgi-bin/mapserv.exe?map=C:/mapas/municipios.map&"
#-- url de acesso - a url que será colado em clients
"wms_srs" "EPSG:29182" #-- sistema de coordenadas de saída = WGS84
END
END
PROJECTION
"init=epsg:29182" #-- sistema de coordenadas de saída = WGS84
END
LAYER
NAME "RGB_2004"
TYPE RASTER
CONNECTION "10.234.85.59,port:5151,sde,user,pass"
CONNECTIONTYPE PLUGIN
PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
DATA "SDE:10.234.85.59,5151,sde,user,pass,sde.user.RGB_2004,footprint"
STATUS DEFAULT
METADATA
"wms_title" "RGB_2004"
END
END
END
In the log generated, the following message appears:
msDrawRaster(): Unable to access file.
(SDE:10.234.85.59,5151,sde,user,pass,sde.user.RGB_2004,footprint)
I'm using MS4W 2.2.7.
All other types of data worked very well.
Does anyone know what is wrong with my mapfile?
View this message in context: http://n2.nabble.com/ArcSDE-9.3-Raster-Mapfile-problem-tp1689552p1689552.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
