[mapserver-users] pdf OUTPUT format for annotation layer not
working
Brent Fraser
bfraser at geoanalytic.com
Fri Dec 19 10:41:31 EST 2008
José,
I ran into that problem a couple of days ago. I had a rogue COLOR object in my LAYER:
LAYER
NAME '082h04_1_0_TO_2520009_0'
TYPE annotation
DATA 'C:\Inetpub\wwwroot\Topo\data\vector\Canvec_50\082\H\082h04_1_0_TO_2520009_0'
STATUS DEFAULT
LABELITEM 'TOPONAME'
CLASSITEM 'TYPE'
CLASS
COLOR 0 0 0 # this causes a "too large for PDF" error
NAME 'TYPE = 4'
EXPRESSION '4'
LABEL
FONT "tuffy5"
TYPE TRUETYPE
COLOR 80 80 80
Taking out the (useless) COLOR object made it work.
Brent Fraser
José María Michia wrote:
> Hi all!
> I get this error message with "TYPE ANNOTATION" in a polygon layer:
> $ shp2img -m ubicacion_regional.map -o p.pdf
> fatal exception: [1906] PDF_moveto: Floating point number 2147483648
> too large for PDF
> With "TYPE polygon" the program runs normally.
> I've tried with MapServer version 5.2.1 and with svn version.
> Ask me the data and the mapfile, so you can try to reproduce this.
> I've opened a ticket in trac system, but, maybe someone in the list
> knows what is wrong with this.
> Thanks for any advice.
> Saludos
> José María
> mapserver-users at lists.osgeo.org
