[mapserver-users] getting error
Frank Warmerdam
warmerdam at pobox.com
Sat Dec 20 11:01:20 EST 2008
muzaffar hussain wrote:
> then i have execute this .ovf in command line as follows
> *C:\ms4w\tools\gdal-ogr>ogrinfo aqidata.ovf
> ERROR 4: Update access not supported for VRT datasources.
> C:\ms4w\tools\mapserv>shp2img -m ogr.map -o test.png
> msDrawMap(): Image handling error. Failed to draw layer named 'MyAqi'. <br>
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `MyAqi'. Fi
> le not found or unsupported format. <br>**
> please help me out from this ,where i have done a mistake
Muzaffar,
It looks like you aqidata.ovf file is in C:\MS4W\tools\gdal-ogr but your
mapfile is in C:\MS4W\tools\mapserv. I don't see anything in your mapfile
indicating how to find aqidata.ovf. For simplicity I would suggest you use
a full path to the .ovf file in the .map file.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
