[mapserver-users] want plot dynamic points in map
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Dec 20 09:48:07 EST 2008
http://www.google.com/search?num=100&hl=en&newwindow=1&q=mapserver-users+plot+gps+points&btnG=Search
might be helpful.
-Steve W
muzaffar hussain wrote:
> hi all
> i am doing project in vehicle tracking system.wat i want is
> ploting dynamic points in the map.
> if point is static means i can able to plot in particular location,my
> map file is mention blow
> *LAYER
> NAME 'gps_point'
> STATUS DEFAULT
> TYPE POINT
> FEATURE
> # This is where you specify position on the map - using a default value
> POINTS 0 0 END
> END
> CLASS
> STYLE
> SYMBOL "marker"
> END
> END
> END
> SYMBOL
> NAME "marker"
> TYPE PIXMAP
> IMAGE "C:\ms4w\apps\ka-map-1.0\htdocs\images\bus.gif"
> #TRANSPARENT 8
> END*
> in the above map file one statement *POINTS 0,0* is there , i am adding
> static image (bus)in the map,
> i want to add dynamic object in the map,that is current location of
> vehicle in the map,i should take the longitude and latitude from database.
> for example
> *POINTS longitude,latitude*
> if anybody is having the sample code,or come across this kind of
> issue,please help me out from this,for the past 1 month i am trying to
> do this,but i am not getting any resource for this.
> please help me out from this.
> thanks in advance
> muzaffar
> mapserver-users at lists.osgeo.org
