[mapserver-users] getting error
muzaffar hussain
mhd.muzaffar at gmail.com
Fri Dec 19 23:28:02 EST 2008
hi
first i have created table in *mysql *as *testdata *which have four fields
*(areaID,x,y,sampleValue)*
then i have created *aqidata.ovf* which have following code mention below
*<OGRVRTDataSource>
<OGRVRTLayer name="aqidata">
<SrcDataSource>MYSQL:aqiTest,user=uuuuu,password=ppppp,host=192.170.1.100,port=3306,tables=testdata</SrcDataSource>
<SrcSQL>SELECT areaID, x, y, sampleValue FROM testdata</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>*
then i have execute this .ovf in command line as follows
*C:\ms4w\tools\gdal-ogr>ogrinfo aqidata.ovf
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `aqidata.ovf'
using driver `VRT' successful.
1: aqidata (Point)*
then i have created map file as follows
*LAYER
NAME "MyAqi"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "aqidata.ovf"
DATA "aqidata"
CLASS
NAME "MyClass"
STYLE
SYMBOL 'circle'
SIZE 15
COLOR 0 255 0
END
END
END
#Circle symbol
SYMBOL
NAME 'circle'
TYPE ellipse
FILLED true
POINTS
1 1
END
END
END
*after that if i try to execute this map file means its showing the error
C:\ms4w\tools\mapserv>shp2img -m ogr.map -o test.png
msDrawMap(): Image handling error. Failed to draw layer named 'MyAqi'. <br>
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `MyAqi'. Fi
le not found or unsupported format. <br>**
please help me out from this ,where i have done a mistake
thanks in advance
muzaffar
On Fri, Dec 19, 2008 at 8:25 PM, Fawcett, David
<David.Fawcett at state.mn.us>wrote:
> Muzaffar,
> I think that we would have to see the text from your map file to figure
> this out.
> What format is your data in? (Based on the name, I have a guess that it is
> possible that you are using MySQL and following the HowTo that I wrote a
> long time ago...)
> If you are using MySQL, it could be that your MapServer binary was not
> compiled with a version of ogr that supports MySQL input. What do you get
> when you type mapserv -v ?
> We definitely need more info to help you.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *muzaffar hussain
> *Sent:* Thursday, December 18, 2008 11:39 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] getting error
> hi
> i am getting the following error if i am executing *"shp2img -m ogr.map
> -o test.png"*
> *msDrawMap(): Image handling error. Failed to draw layer named 'MyAqi'.
> <br>
> `MyAqi'. Fi
> please help out from this.
> thanks in advance
> muzaffar
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081220/afc1f72c/attachment.html
