[mapserver-users] How to Create Legend for Single Layer
bartvde at osgis.nl
bartvde at osgis.nl
Tue Dec 23 03:41:23 EST 2008
Before you call drawLegend, change the visibility of all other layers to
false (status == MS_OFF), the legend only draws for the visible layers.
When you're done, restore the visibility.
Best regards,
Bart
> Hi,
> Thanks for your great response.I am not using CGI.I am using asp
> C#.net.I have created a method which generates legend.But it is doing for
> all the layers.And my layer does the expression property.based on the
> expression I m displaying polygon.
> Below code is for trying to get legend for single layer.But it is not
> working.
> layer = MapFunction.Map.getLayerByName("TestLayer");
> classObj classLegend = new classObj(layer);
> imageObj imagelegend = MapFunction.Map.drawLegend();
> string strFile ="C:\\temp\\test.png";
> imagelegend.save(strFile,MapFunction.Map);
> Thanks
> Venkat.
> -----Original Message-----
> From: Subha Ramakrishnan [mailto:subha at gslab.com]
> Sent: Tuesday, December 23, 2008 2:00 PM
> To: Venkat Rao Tammineni
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] How to Create Legend for Single Layer
> Hi,
> You can do so using mode=legend request. Eg:
> "http://localhost/cgi-bin/mapserv?mode=legend&map=mapfile&layer=layer_name"
> This will give the legend only for the layer that you pass in the url.
> In addition to this, is there a facility to generate legend for a layer
> with a filter, where the filter takes in parameters passed from URL to
> generate polygons??
> Thanks & regards,
> Subha
> Venkat Rao Tammineni wrote:
>> Dear All,
>> I want to create Legend for Single layer. I have 5 layers on my Map.
>> But I need to generate legend for single layer. Is it possible to
>> generate Legend for single layer. If some one done the same task.
>> Please let me know.
>> I am waiting for your great response.
>> Thanks,
>> Venkat.
>> This message has been scanned for viruses and
>> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and
>> is
>> believed to be clean.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
