[mapserver-users] What is required to be able to query point layers?
nikos at maich.gr
nikos at maich.gr
Thu Dec 25 11:46:44 EST 2008
Hello and Merry X-mas to all,
Bit of a bother here. I've received a point layer to add to my current app,
and while I'm able to render it, I cannot get a query to work.
Even with a huge tolerance, clicking on points does not return a result.
The shapefile check outs fine and queries in ESRI and Qgis apps.
Using MS 5.3-dev from FWTools, on XP
would appreciate some help,
Attached is the map file,
regards,
nikos
map
extent 311610.0 4326810.0 346410.0 4363900.0
imagecolor 255 255 255
name "farditsa1"
shapepath "data"
size 600 600
status on
symbolset "symbols/all.sym"
units meters
# 1 scalebar #none
scalebar
backgroundcolor 255 255 0
color 255 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent true
units meters
# 1 label #none
label
backgroundcolor 0 0 0
color 255 255 0
size tiny
end
end
# 2 layer 2006_xy_opekepe_Karditsa
layer
classitem "AFM"
data "2006_xy_opekepe_Karditsa"
footer "2006_xy_opekepe_Karditsa_footer.html"
group "2006_xy_opekepe_Karditsa"
header "2006_xy_opekepe_Karditsa_header.html"
labelcache on
labelitem "AFM"
name "2006_xy_opekepe_Karditsa"
postlabelcache true
status on
type point
TOLERANCE 600
TOLERANCEUNITS pixels
TRANSPARENCY 60
# 1 class 2006_xy_opekepe_Karditsa_1
class
STYLE
SYMBOL 'CIRCLE'
SIZE 10
OUTLINECOLOR 0 0 0
COLOR 24 93 38
END
END
end
#Circle symbol
SYMBOL
NAME 'CIRCLE'
TYPE ellipse
FILLED true
POINTS
1 1
END
END
# 3 web farditsa1.html
web
footer "farditsa1_footer.html"
header "farditsa1_header.html"
imagepath "/web/farditsa1/tmp/"
imageurl "/farditsa1/tmp/"
template "farditsa1.html"
end
# 4 querymap hilite
querymap
color 255 0 0
size 200 200
status on
style hilite
end
# 5 reference graphics/reference.gif
reference
color -1 -1 -1
image "graphics/reference.gif"
outlinecolor 255 0 0
size 120 120
status on
end
# 6 legend #none
legend
keysize 18 12
status on
# 1 label #none
label
color 0 0 89
size medium
type bitmap
end
end
end
