[mapserver-users] What is required to be able to query point
layers?
José María Michia
jose.maria.michia at gmail.com
Thu Dec 25 19:43:21 EST 2008
2008/12/25 <nikos at maich.gr>
> Hello and Merry X-mas to all,
> Bit of a bother here. I've received a point layer to add to my current app,
> and while I'm able to render it, I cannot get a query to work.
> Even with a huge tolerance, clicking on points does not return a result.
> The shapefile check outs fine and queries in ESRI and Qgis apps.
> Using MS 5.3-dev from FWTools, on XP
> would appreciate some help,
> Attached is the map file,
> regards,
> nikos
I believe that the LAYER/CLASS object lacks the TEMPLATE parameter.
You may want to check this.
For example, you must add a line in this way:
> map
> # 2 layer 2006_xy_opekepe_Karditsa
> layer
> classitem "AFM"
> data "2006_xy_opekepe_Karditsa"
# Add this here:
> template "2006_xy_opekepe_Karditsa_template.html"
> footer "2006_xy_opekepe_Karditsa_footer.html"
> group "2006_xy_opekepe_Karditsa"
> header "2006_xy_opekepe_Karditsa_header.html"
> labelcache on
> labelitem "AFM"
> name "2006_xy_opekepe_Karditsa"
> postlabelcache true
> status on
> type point
> TOLERANCE 600
> TOLERANCEUNITS pixels
> TRANSPARENCY 60
> # 1 class 2006_xy_opekepe_Karditsa_1
> class
> STYLE
> SYMBOL 'CIRCLE'
> SIZE 10
> OUTLINECOLOR 0 0 0
> COLOR 24 93 38
> END
> END
> end
Saludos
José María
