[mapserver-users] What is required to be able to query
pointlayers?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Dec 26 02:25:53 EST 2008
Document http://mapserver.gis.umn.edu/docs/howto/wms_server tells:
> Configuring for GetFeatureInfo Requests:
> You must set the layer TEMPLATE parameter for the layer to be queryable by GetFeatureInfo
> requests. For requests of type "text/html" you should also set the layer HEADER and FOOTER
> parameters.
(My addition here: The file that TEMPLATE refers to must exist in your computer, but it can be even an empty file).
> For GetFeatureInfo requests of GML you must set the layer to DUMP TRUE in the mapfile. As of
> MapServer 4.6 you must also set the gml_* metadata for the layer attributes to be served (see the
> Layer Object metadata in the Reference Section later in this document).
Thus, try these steps:
1) add DUMP TRUE
2) add TEMPLATE c:\ms4w\apps\template\foo.html and create an empty foo.html file with that name
3) add to layer metadata "ows_include_items" "all"
That should be enough.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: José María Michia
Lähetetty: pe 26.12.2008 2:43
Vastaanottaja: nikos at maich.gr
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] What is required to be able to query pointlayers?
2008/12/25 <nikos at maich.gr>
> Hello and Merry X-mas to all,
> Bit of a bother here. I've received a point layer to add to my current app,
> and while I'm able to render it, I cannot get a query to work.
> Even with a huge tolerance, clicking on points does not return a result.
> The shapefile check outs fine and queries in ESRI and Qgis apps.
> Using MS 5.3-dev from FWTools, on XP
> would appreciate some help,
> Attached is the map file,
> regards,
> nikos
I believe that the LAYER/CLASS object lacks the TEMPLATE parameter.
You may want to check this.
For example, you must add a line in this way:
> map
> # 2 layer 2006_xy_opekepe_Karditsa
> layer
> classitem "AFM"
> data "2006_xy_opekepe_Karditsa"
# Add this here:
> template "2006_xy_opekepe_Karditsa_template.html"
> footer "2006_xy_opekepe_Karditsa_footer.html"
> group "2006_xy_opekepe_Karditsa"
> header "2006_xy_opekepe_Karditsa_header.html"
> labelcache on
> labelitem "AFM"
> name "2006_xy_opekepe_Karditsa"
> postlabelcache true
> status on
> type point
> TOLERANCE 600
> TOLERANCEUNITS pixels
> TRANSPARENCY 60
> # 1 class 2006_xy_opekepe_Karditsa_1
> class
> STYLE
> SYMBOL 'CIRCLE'
> SIZE 10
> OUTLINECOLOR 0 0 0
> COLOR 24 93 38
> END
> END
> end
Saludos
José María
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
