[mapserver-users] Re: changing layer projection
Chad Ringenberg
chad at agridatainc.com
Fri Dec 26 10:07:49 EST 2008
Since I haven't received a response yet on my question I will explain a little further what I'm am doing. I have numerous raster images from different sources that I dynamically load via cgi. Sometimes these images are in a different projection than my resulting map. I can still change the data parameter for the raster layer but have been unable to change the projection. I was able to do this in 4.1 but it appears to have been removed in 5.x or a bug was introduced.
Can the projection parameter for a layer be changed in 5.x or should I file a bug report?
Thanks,
Chad
----- Original Message -----
To: mapserver-users at lists.osgeo.org
Sent: Monday, December 22, 2008 3:43 PM
Subject: changing layer projection
I have been updating my mapserver cgi application from 4.10 to 5.21 and it appears we have lost the ability to change a layers projection parameter from the url. In version 4.1 I could change it with "map_layername_projection=init=epsg:26914". With 5.21 I have tried "map_layer[layername]_projection=init=epsg:26914" and numerous other combinations to no avail.
Does anyone know how to change a layers projection with 5.21?
Thanks,
Chad
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081226/b9742258/attachment.html
