[mapserver-users] Re: changing layer projection
Steve Lime
Steve.Lime at DNR.State.MN.US
Fri Dec 26 10:20:39 EST 2008
I sent a reply to the list on the 23rd, did you see/try that? The proper syntax for
a layer projection is:
map_layer[layername]=PROJECTION%20init%3Depsg%3A26914%20END
I checked the code and a projection can be modified by URL.
Steve
>>> On 12/26/2008 at 9:07 AM, in message
<288EED89877E4D398C786CE66E114BAC at ChadsVista>, "Chad Ringenberg"
<chad at agridatainc.com> wrote:
> Since I haven't received a response yet on my question I will explain a
> little further what I'm am doing. I have numerous raster images from
> different sources that I dynamically load via cgi. Sometimes these images
> are in a different projection than my resulting map. I can still change the
> data parameter for the raster layer but have been unable to change the
> projection. I was able to do this in 4.1 but it appears to have been removed
> in 5.x or a bug was introduced.
> Can the projection parameter for a layer be changed in 5.x or should I file
> a bug report?
> Thanks,
> Chad
> ----- Original Message -----
> From: Chad Ringenberg
> To: mapserver-users at lists.osgeo.org
> Sent: Monday, December 22, 2008 3:43 PM
> Subject: changing layer projection
> I have been updating my mapserver cgi application from 4.10 to 5.21 and it
> appears we have lost the ability to change a layers projection parameter from
> the url. In version 4.1 I could change it with
> "map_layername_projection=init=epsg:26914". With 5.21 I have tried
> "map_layer[layername]_projection=init=epsg:26914" and numerous other
> combinations to no avail.
> Does anyone know how to change a layers projection with 5.21?
> Thanks,
> Chad
