[mapserver-users] MapServer Symbol Conversion from Polyline Points
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Dec 29 05:59:07 EST 2008
Just to add a wee bit to this. I have a number of symbols that I would like
to recreate in MapServer. I have an image of what they should look like and
I have the arrays of polyline points. What I don't really know is the
limitations of the MapServer vector points i.e. the maximum number of points
that can be used and the highest positive/negative numbers that can be used.
I believe that "-99" works as 'pen up' but does that mean that -98 and 98
are the maximum? Also, do the point values have to be integer values? If
not, how many numbers after the point e.g. 1.12345 etc.
If I take the polyline points like the following then the server throws a
CGI wobbly and needs restarting:
SYMBOL
NAME 'boulderGeometry'
TYPE VECTOR
FILLED FALSE
POINTS
-0.154 0.236
-0.111 0.365
-0.116 0.501
-0.165 0.616
-0.170 0.627
-0.264 0.724
-0.490 0.826
-0.682 0.889
-0.885 0.900
-1.083 0.858
-1.264 0.767
-1.415 0.631
-1.521 0.466
-1.558 0.199
-1.538 -0.071
-1.462 -0.329
-1.333 -0.566
-1.156 -0.771
-99 -99
1.755 -0.819
1.534 -0.804
0.832 -0.857
0.129 -0.824
-0.450 -0.769
-1.032 -0.767
-1.612 -0.819
-99 -99
1.640 -0.804
1.620 -0.589
1.392 -0.388
1.122 -0.248
-99 -99
0.311 -0.526
0.520 -0.573
0.732 -0.554
0.930 -0.472
1.093 -0.335
1.097 -0.329
1.101 -0.323
1.105 -0.317
1.108 -0.311
1.111 -0.304
1.113 -0.298
1.115 -0.291
1.117 -0.284
1.118 -0.277
1.118 -0.270
1.119 -0.263
1.118 -0.256
1.118 -0.249
1.117 -0.242
1.115 -0.235
1.113 -0.229
1.111 -0.222
1.108 -0.216
1.105 -0.209
1.101 -0.203
1.097 -0.198
1.093 -0.192
1.088 -0.187
1.083 -0.182
1.078 -0.177
1.073 -0.173
1.067 -0.169
1.061 -0.165
1.054 -0.162
0.637 0.198
0.393 0.388
0.118 0.530
-0.165 0.616
-0.178,0.619
END # POINTS
END # SYMBOL
If I take just part of the above then it still doesn't work:
SYMBOL
TYPE VECTOR
FILLED FALSE
POINTS
-0.154 0.236
-0.111 0.365
-0.116 0.501
-0.165 0.616
-0.170 0.627
END # POINTS
END # SYMBOL
Any help most greatly appreciated.
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: 28 December 2008 21:39
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] MapServer Symbol Conversion from Polyline Points
I've been struggling with this problem all day and cannot make any progress.
I hope that someone can help.
I want to convert a polyline points array into a MapServer Symbol but keep
getting errors.
Here's the polyline array:
<polyline points='-0.154,0.236 -0.111,0.365 -0.116,0.501 -
0.165,0.616 -0.170,0.627 -0.264,0.724 -0.490,0.826 -0.682,0.889
-0.885,0.900 -1.083,0.858 -1.264,0.767 -1.415,0.631 -1.521,0.466
-1.558,0.199 -1.538,-0.071 -1.462,-0.329 -1.333,-0.566 -1.156,-
0.771' />
<polyline points='1.755,-0.819 1.534,-0.804 0.832,-0.857 0.129,-
0.824 -0.450,-0.769 -1.032,-0.767 -1.612,-0.819' />
<polyline points='1.640,-0.804 1.620,-0.589 1.392,-0.388 1.122,-
0.248' />
<polyline points='0.311,-0.526 0.520,-0.573 0.732,-0.554 0.930,-
0.472 1.093,-0.335 1.097,-0.329 1.101,-0.323 1.105,-0.317
1.108,-0.311 1.111,-0.304 1.113,-0.298 1.115,-0.291 1.117,-0.284
1.118,-0.277 1.118,-0.270 1.119,-0.263 1.118,-0.256 1.118,-0.249
1.117,-0.242 1.115,-0.235 1.113,-0.229 1.111,-0.222 1.108,-0.216
1.105,-0.209 1.101,-0.203 1.097,-0.198 1.093,-0.192 1.088,-0.187
1.083,-0.182 1.078,-0.177 1.073,-0.173 1.067,-0.169 1.061,-0.165
1.054,-0.162 0.637,0.198 0.393,0.388 0.118,0.530 -0.165,0.616 -
0.178,0.619' />
And here's a depiction of the symbol I need to create:
http://www.dkerr.co.uk/boulderGeography.gif
Many thanks.
Regards,
Donald
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
