[mapserver-users] MapServer Symbol Conversion from Polyline Points
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Dec 29 07:58:26 EST 2008
Thomas,
Thanks for your prompt reply.
>> If I take just part of the above then it still doesn't work:
>> SYMBOL
>> NAME 'boulderGeometry'
>> TYPE VECTOR
>> FILLED FALSE
>> POINTS
>> -0.154 0.236
>> -0.111 0.365
>> -0.116 0.501
>> -0.165 0.616
>> -0.170 0.627
>> END # POINTS
>> END # SYMBOL
> There's a limitation with the vector code that expects all
> values to be positive when computing the symbol size. I'm
> hoping this will be fixed in 5.4 / 6.0
Is that the reason why the above appears not to work i.e. the size issue? I
will try changing everything to a positive number to see if that works.
As a side issue, do the positive/negative numbers have a bearing on the
anchor point of the symbol or is that always in the centre of the symbol?
Many thanks.
Regards,
Donald
