[mapserver-users] MapServer Symbol Conversion from Polyline Points
Fawcett, David
David.Fawcett at state.mn.us
Mon Dec 29 09:50:33 EST 2008
Another potential solution would be to create a true type font character
and use that as your symbol.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas
bonfort
Sent: Monday, December 29, 2008 7:06 AM
To: Donald Kerr
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapServer Symbol Conversion from Polyline
Points
On Mon, Dec 29, 2008 at 13:58, Donald Kerr <donald.kerr at dkerr.co.uk>
wrote:
> Thomas,
> Thanks for your prompt reply.
>>> If I take just part of the above then it still doesn't work:
>>> SYMBOL
>>> NAME 'boulderGeometry'
>>> TYPE VECTOR
>>> FILLED FALSE
>>> POINTS
>>> -0.154 0.236
>>> -0.111 0.365
>>> -0.116 0.501
>>> -0.165 0.616
>>> -0.170 0.627
>>> END # POINTS
>>> END # SYMBOL
>> There's a limitation with the vector code that expects all values to
>> be positive when computing the symbol size. I'm hoping this will be
>> fixed in 5.4 / 6.0
> Is that the reason why the above appears not to work i.e. the size
> issue? I will try changing everything to a positive number to see if
> that works.
probably
> As a side issue, do the positive/negative numbers have a bearing on
> the anchor point of the symbol or is that always in the centre of the
> symbol?
as of now, the symbol is centered on the anchor point. I'd be in favor
of having a way to specify the anchor point, either by fixing it on 0,0
, or by specifying it alongside the symbol, eg ANCHORPOINT 0.3 2
regards,
thomas
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
