[mapserver-users] LABEL - POSITION and FONT Calculations
José María Michia
jose.maria.michia at gmail.com
Mon Dec 29 07:32:35 PST 2008
2008/12/29 Donald Kerr <donald.kerr at dkerr.co.uk>:
> I have a problem that has me stumped.
> I am trying to place text on a map as a LABEL which I can successfully do
> with the following code:
> LAYER CONNECTIONTYPE postgis
> NAME "CartographicText"
> CONNECTION "user=postgres dbname=MasterMap host=localhost"
> DATA "geom FROM (SELECT toid, featurecode, textstring,
> orientation/10 AS orientation, fontnumber, anchorposition, textstyle, geom
> FROM cartographictext) AS foo USING UNIQUE toid"
> METADATA
> "IMAGEFORMAT" "AGGA"
> END
> STATUS DEFAULT
> MINSCALEDENOM 1
> MAXSCALEDENOM 1300
> SYMBOLSCALEDENOM 1250
> TYPE ANNOTATION
> LABELITEM textstring
> CLASS
> # Road Name Or Classification
> EXPRESSION ([featurecode] = 10169)
> LABEL
> TYPE truetype
> FONT arial
> SIZE 10
> MAXSIZE 30
> MINSIZE 0
> COLOR 0 0 0
> ANTIALIAS TRUE
> ANGLE [orientation]
> END # LABEL
> END # CLASS
> CLASS
> # Building or Structure Text
> EXPRESSION ([featurecode] = 10026)
> LABEL
> TYPE truetype
> FONT arial
> SIZE 7
> MAXSIZE 21
> MINSIZE 0
> COLOR 0 0 0
> ANTIALIAS TRUE
> ANGLE [orientation]
> END # LABEL
> END # CLASS
> END # LAYER
> I want to add POSITION based on [anchorposition] from the database.
> The database grid for anchorposition is as follows:
> 2 5 8
> 1 4 7
> 0 3 6
> Whereas MapServer is as follows
> ul uc ur
> cl cc cr
> ll lc lr
> Which is probably:
> 0 1 2
> 3 4 5
> 6 7 8
> The question is: Is it possible to take the values from the database and
> convert them for use within the LABEL e.g. 2 = ul = "POSITION ul" or 5 = uc
> = "POSITION uc"?
I think that, yes! The numeric values for these constants are defined
in mapserv.h:
enum MS_POSITIONS_ENUM {MS_UL=101, MS_LR, MS_UR, MS_LL, MS_CR, MS_CL,
MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY , MS_FOLLOW};
The positions following to the MS_UL, adopt their values automaticly
(MS_LR=102, and so on).
> I would also like to be able to change the Font based on [fontnumber] from
> the database e.g. 0 = Arial = "FONT arial" or 1 = Times = "FONT times"
> Are these things possible?
Yes again. You must define your fonts in a FONTSET file. These file
have entries like this one:
"times /archivos/mapping/fonts/times.ttf
arial /archivos/mapping/fonts/arial.ttf
The first column, is the name of the font, and the second column is
the full path to the font. You can choose the name, so you can choose
a number as font name:
0 /archivos/mapping/fonts/times.ttf
1 /archivos/mapping/fonts/arial.ttf
I'm not sure if numbers are allowed in font names. Anyway, you can do
some string manipulation to get the desired result.
> Many thanks.
> Regards,
> Donald Kerr
I hope I have understood. And I hope that you understand myself.
Saludos
José María
More information about the MapServer-users
