[mapserver-users] Image not rendered on large monitors.
thomas bonfort
thomas.bonfort at gmail.com
Tue Dec 30 05:47:31 EST 2008
hi,
set maxsize to something bigger, eg 4096
regards,
thomas
On Tue, Dec 30, 2008 at 11:45, Subha Ramakrishnan <subha at gslab.com> wrote:
> Hi,
> We have built a map based web portal using Openlayers and Mapserver 5.0.2.
> We have multiple layers being rendered using Mapserver.
> But we are facing an issue here.
> On large monitors with the resolutions, "1680 x 1050", "1856 x 1392" ,"1920
> x 1080"(21 inches and above), mapserver doesn't render images.
> It throws an error saying "WMS server error.Image size out of range,Width
> and height must be between 1 and 2048 pixels."
> I have tried setting the "MAXSIZE" as 2048 in my map file but it doesn't
> seem to work.
> My mapfile is as follows:
> map
> size 725 800
> imagetype png
> imagecolor 225 225 225
> projection
> "init=epsg:4326"
> end
> extent 60 0 100 40
> maxsize 2048
> outputformat
> name "jpg"
> driver "GD/JPEG"
> extension "jpg"
> formatoption "QUALITY=85"
> end
> layer
> name xyz
> connectiontype postgis
> connection "user= abc dbname=qwe password=fgg host=localhost"
> group world
> type polygon
> status on
> data "topology from table"
> class
> style
> width 3
> outlinecolor 000 000 255
> end
> end
> end
> end
> Is there something wrong that in the mapfile? Or if there is any other
> solution that someone knows, please let me know.
> Thanks for the help.
> Regards,
> Subha
> mapserver-users at lists.osgeo.org
